20 Most Recent
Samsung 80GB INTERNAL 3.5- IN SATA HDD 7200RPM 8MB 1- IN HEIGHT 3- YEAR WARR. BULK (SP0802C) Hard Drive Questions & Answers
I have my desktop formatted,,and it turns
Hi, it seems Windows is not installed well or the hard disk could be faulty, the first step could be to check data and power cables among motherboard and power supply to hard disk and if that's OK, try to do a clean Windows installation, if this fails maybe the hard disk has the boot sector physically damaged and it's better to replace it.
Primary Master (Samsung HD080HJ/P) Your
go into control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured you might be able to uninstall then reinstall some of these files/software
also you might try
test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
SAMSUNG 40GB HARD DISK MOTOR IS NOT ROTATING AND
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
My hard disk is unreadable or its damaged i cant
> Samsung ... 80 GB ... 3-year warranty .. unreadable ...
Sorry, but your disk-drive has stopped working (compare it to writing in pen onto greasy paper, and then trying to read what you wrote -- you won't get 100% readability).
The only "good-news" is that the warranty for your disk-drive could still be valid,
meaning that Samsung will replace the disk-drive, at their cost.
Can i make my 80GB hard drive to 100GB?
This is not possible, 80Gb is 80Gb and 100gb is 100gb, but I am afraid, even if you like to replace, you'll not be able to get 100gb since it's no a standard Hard disk capacity. If you are trying to upgrade, then you can find 120gb, 160gb, 250gb, 320gb etc...
Good luck.
Thanks for using FixYa.
My computer displays the normal windows with its
when your desktop loads, click on start menu, run, and wright: cmd
then wright: shutdown -a (in the command promp)
and hitt enter.
the dialog should disappear, restart the pc and check if it comes again that u need to make the same prosses again plus, going to msconfig (righting it in run), and then to the bookmark saying start up and uncheck any suspisious programe, locate its files,delete them,apply and restart again.
Cant able to format HD
To re-install XP over it's self. Put the CD in your cdrom drive. Start the system & press the F5 key every 2 seconds. This will load a boot menue. Using your keyboards up & down arrow keys highlit the cdrom drive & press enter. You will see to boot to the cd press any key, press the space bar. XP will start to load. Choose the correct options for a re-install.
Enjoy!
please vote...
How do I find the instruction manual with codes for my Samsung 32" curved screen monitor ?
Manufacturer's Website: Go to the manufacturer's website (visit the official Samsung website in this case). Click on the support section, search your monitor model by product name or model number, and download your monitor model for the user manual. User manuals usually list codes and other relevant information.
User Manuals Online: Many people post user manuals online for all types of electronic devices and peripherals. You can search for your monitor and look for the user manual at sites such as ManualsLib, ManualsOnline, or Retrevo. Most of these sites will catalog user manuals for a wide variety of devices posted online by users and are normally free to access.
Physical User Manual: If you still have the original box or packaging with your monitor, there might be a copy of the user's manual in that box or enclosed. It might be in an actual printed booklet or perhaps just some links to online resources. Check under a section entitled 'Remote Control Codes' or 'Setup Instructions'.
Contact Samsung Support: If no luck finding it to download or to help you, there is contact support available, they should know where that information is, and be able to send it to you or refer you.
With these, you should be able to find the user manual for your Samsung 32" curved screen display and enter those codes.
4/13/2024 10:32:28 AM •
Samsung...
Answered
on Apr 13, 2024
Maquina de lavar Samsung wf90f5e5u4w
ENGLISH ONLY please.
Samsung washing machine wf90f5e5u4w
Hello good afternoon, I want to ask for help, I have a faulty module and I wanted to ask if you have the electronic diagram for the Samsung DC92-01240C washing machine, the machine model wf90f5e5u4w, I would really appreciate it if you could, thank you. greetings Antonio Paulo
Steam Wash, Washers Support ' Samsung Care US
Samsung
https://www.samsung.com > washers > front-load > ste...
Get the latest drivers, manuals, firmware, and software. Learn more. Request repair service. Arrange for a service visit at home, schedule a walk- ...
https://www.google.com/search?q=Samsung+DC92-01240C+service+manual
12/4/2023 10:19:25 PM •
Samsung...
Answered
on Dec 04, 2023
