20 Most Recent
Graco Ready2Grow LX Baby Stoller & SnugRide 30 Twin Travel System Questions & Answers
Graco Ready2Grow stroller rear axle brake broken
Graco Customer Support is available Monday through Friday, 8am to 5pm EST.800-345-4109 (
US) 800-667-8184 (
Canada - 8:30am to 5pm EST) ===========================Graco UK & IrelandHalifax AvenueFradley ParkLichfieldStaffordshireWS13 8SS Consumer Service Desk (UK enquiries only) Dialling from UK: 0844 412 1212Dialling from ROI: 0818 221 422
[email protected] Note: When emailing, please mention the model number which can be found on either the rear left leg or under the footrest.
How do you remove canopy from graco sweetpeace
You need to remove the center of the part that connects to the chair. Use a thin screwdriver into the center and then pry each of the two tabs outward from the center. As you unhook it, you will be able to pry it out and then the attachment mechanism will pull off
How to remove seat wire, after putting it in wrong on the Graco uno2duo stroller?
This question was posted a long time ago, but no one answered it correctly. If you put the wire in backward, look on the end of where the wire was inserted. You made have to move the fabric to see it. There are holes. Use something to push in the metal piece that is showing as you pull out each side of the wire. I used a house key to push in the button while I removed the wire.
