20 Most Recent
13 HP Engine GX390 OHV Horizontal Shaft Questions & Answers
Loss of power and blue smoke
loss of power with blue smoke means the engine is using oil and possibly getting ready to seize up. Pull the spark plug and see what color it is, if it has small flecks of metal then the piston is scored. When was the air filter replaced and how does it look, entry of dirt will destroy an engine. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/darryl_24e8d8d43e609e3c
Why cant I pull the starter cord
If its on the compression stroke when you are pulling it will be hard to pull it, because you're fighting against the compression of the engine, make sure the valves are at the correct position and not fully closed when you are pulling.
GX390 runs and shuts off
have you checked the engine oil. most models have an oil motion pick up. they are fitted to most lawn mowers as well when the oil gets week it does not lift and engine will just cut out. replace oil with 20/50 oil.
Lightbulb replace hondaaccordradio1998
I got this free Pdf manual from reliable-store for free and I don't think Ive visited a mechanic or fixya for help for more than 3-4 times out of the 20 times I fixed the chipper in these 4 yearsmust try this bitman and reliable-store. Both are good
Gx610 Honda v-twin small engine one side want fire
Hi, If you did the usual testing (comp,Carb cleaning, etc.) then I would go to the electronic ignition box if it has one. I've been fooled before. Checking for spark, wire off, or plug out, isn't the same as a plug under compression , Good luck.
