20 Most Recent
Shuttle AB45 (SHUTAB45) Motherboard Questions & Answers
Phoenixbios d686 for 017578387 1998
Hello visit the mainboards home page, for download of the bios file.Flashing the bios with a wrong one, WILL destroy the mainboard.And don`t upgrade the bios when the system is running fine.Good luck
Keyboard will not type.
In your BIOS, check your security settings and if for some strange reason your keyboard is not enabled upon startup, enable it. Otherwise it could be a faulty keyboard.
Shuttle ab45 v1.2 motherboard, the pc monitor doesn't light up
hi im josh in cebu phils.may i help you. Friend your 478 mainboard doesnt work.? All you have to do is to check the hardware attached on it like hard drive video card memory and most of all the power supply cable.be sure you seated it very well to avoid loose connection. this can cause no display or not working. try to check alson if your pwer supply has enough current to support the mainboard and alson the processor compatiblity with the mainboard. good luck hope i helped you.
Repair ashuttle 250 psu
If the "250" is referring to the PSU's wattage, I think we have found the problem. Please purchase a 500 watt or higher PSU with a 80 percent silver or higher rating and you will be back up and running, that is if the motherboard is indeed good.
4/7/2015 9:02:32 PM •
Shuttle...
Answered
on Apr 07, 2015
