20 Most Recent RIM BlackBerry 7250 Questions & Answers
5answers
Blackberry not charging
i had this happen a while back on my htc 8120 and how i fixed it was take a usb cable to a computer and cut the mini usb off in there u will find a green black and red wire well cut the green wire and strip the black and red wire u will notice on your battery there are four post 2 hots and 2 negs take the red wire and split so it makes 2 and take the negative and split so it makes 2 now plug the usb into ur pc and touch the red wires to the 2 positive and take the 2 blacks and touch them to the 2 negatives it will only take a minute or so all u are trying to do here is jump the battery so your black berry has just enough juice to start so u can charge it.
3/1/2013 9:51:00 PM • RIM BlackBerry... • Answered on Mar 01, 2013
0answers
0answers
Where can I Download driver
Do the following steps: 1) visit the following url https://swdownloads.blackberry.com/Downloads/entry.do?code=02A32AD2669E6FE298E607FE7CC0E1A0
2) Select the product " Blackberry 7250 wireless handheld (TM), then click "Next"
3) Click on the "download software link"
9/11/2011 10:29:03 PM • RIM BlackBerry... • Answered on Sep 11, 2011
Blackberry has no lights on
The device probably needs to be reset. While the handset is on, simply take out the battery, wait 1 minute, reinstall the battery, and power the device back up. If this does not resolve your issue, then you may be looking at something more serious. There are cellular handset repair shops, one in particular is called CPR, they specialize in cellular handset repair, just not sure if you have one in your vicinity. If not, there should be a similar company that you can use.
3/7/2011 9:03:01 PM • RIM BlackBerry... • Answered on Mar 07, 2011
2answers
My blackberry storm suddenly does not charge up
It could be that your USB charging port on your device is damaged. There is an external battery charger available for this device: http://www.amazon.com/Blackberry-7230-External-Battery-Charger/dp/B0009TCB6S/ref=sr_1_2?ie=UTF8&s=wireless&qid=1263461859&sr=8-2
2/24/2011 1:14:14 AM • RIM BlackBerry... • Answered on Feb 24, 2011
2answers
Music and pictures on blackberry 7250
Transferring media files back and forth between your phone and your computer is quite easy if you download the "Blackberry Desktop Manager" software from Blackberry.com. There is one button on the main screen that will say either "Media" or "Media Manager" when you have the software installed, and will allow you to copy music, songs, files from your computer to the phone or vice-versa. Hint: Always open the BB Desktop Software Manager on your computer first, before connection your phone with a USB cable. Will save you hours of time!
10/7/2010 5:32:32 AM • RIM BlackBerry... • Answered on Oct 07, 2010
4answers
CAN BLACKBERRY 7250 SUPPORT RINGTONES
Hi fix all your rim blackberry problem for cheap
www.e-repairs.co.uk
8/23/2010 8:31:04 PM • RIM BlackBerry... • Answered on Aug 23, 2010
Screen locks up and it also starts dialing numbers
your mobile's keypad is short, you have to show it to some mobile technician
8/14/2010 10:51:32 PM • RIM BlackBerry... • Answered on Aug 14, 2010
Unlock code for verzion
You can get your Verizon unlocked online, there is no service available that can provide code for free.
Here is the link that I used for my BlackBerry Tour 9630 to unlock
http://mobileunlockingcode.com/verizon_blackberry_mobile_imei_unlock_code.html
The service is fast, customer support is great, and above all they accept Paypal, which is a peace of mind for any buyer.
Hope this is helpful
7/18/2010 7:36:04 PM • RIM BlackBerry... • Answered on Jul 18, 2010
My blackberry 8800 will not charge even when i put
First Option:Please change The Phone Bettery and charger and check The check The Phone charging
IF Charging Problem will Not Solved So
Secend Option:Your Phone charging IC Fault SO Please change charging IC And charging Problem will SOlved
thanks.
7/8/2010 7:56:24 AM • RIM BlackBerry... • Answered on Jul 08, 2010
No browser on my blackberry 7250
Hello
You have to unlock that BB first
This unlock code provider generate full LEGAL unlock code direct from Blackberry server which wont void your warranty, & generate code based on your IMEI, means individual code for every blackberry set.
After unlocking from this provider's code your blackberry not only work with single network, you can use your Blackberry in any part of world with any network including your browser & MMS picture messaging to work, yes with just one time entering code from your keypad.
They unlock from network who locked your blackberry
This site will help you a lot & good email & 24/7 phone support
5/11/2010 10:14:56 PM • RIM BlackBerry... • Answered on May 11, 2010
I have an old Blackberry 7250. I'm not able to get
congestion must probably sometime phones have a mind of their own
4/21/2010 10:30:05 PM • RIM BlackBerry... • Answered on Apr 21, 2010
Bought BB 8830 off friend, still has his email
You have to use the wipe setting in the settings of the phone this will take some time when it does it but it well wipe everything. If this dont work then you have use MobileUnlockers.com software to reconfigure the settings of the phone
4/4/2010 12:39:36 AM • RIM BlackBerry... • Answered on Apr 04, 2010
Battery drained not charging blackberry
Might need a new battery. they have a life span generally of 2 years. Found the batteries from E-bay are inexpensive and I have had good luck with them.
4/3/2010 4:48:20 PM • RIM BlackBerry... • Answered on Apr 03, 2010
0answers
Blackberry wont charge
Could be that your USB port is defective, and thus your battery is not getting charged. You can purchase and external battery Charger for your model and see if that helps to charge your Battery: http://www.amazon.com/Blackberry-7230-External-Battery-Charger/dp/B0009TCB6S/ref=sr_1_2?ie=UTF8&s=wireless&qid=1263277541&sr=8-2
1/12/2010 6:27:29 AM • RIM BlackBerry... • Answered on Jan 12, 2010
2answers
BB 7250 won't switch on
Something you can try. Open up Desktop Manager (with the BlackBerry unconnected) open up the Application Loader. Before hitting next, pull the battery out of the 7750 for 5 to 10 seconds, then quickly put the battery back in, connect the BlackBerry, and hit next on the application loader. This should kickstart Application Loader to find the BlackBerry and allow you to reload the handheld software. So, make sure you have the handheld software installed on your comptuer (which you already do)
12/20/2009 1:47:30 PM • RIM BlackBerry... • Answered on Dec 20, 2009
RIM BlackBerry 7250 Logo
113 questions posted
Top RIM Computers & Internet Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Alexander
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
BlackBerry RIM
  • BlackBerry RIM
Most Popular Question
blackberry not charging
  • Computers & Internet
