20 Most Recent HP Officejet Pro 8600 e-All-in-One - multifunction fax / copier / printer / scanner color Questions & Answers
No other way except to hinge it open and get a hold of the paper.
HP Officejet Pro... | Answered on Feb 04, 2019
Replace the depleted cartridge. It's out of ink.
Make sure that plug is in working order by plugging something else into it. If you need to get to the power unit inside the printer to test it, here's a video on how to get to power supply:
TRY UNPLUGGING IT FOR A MINUTE OR SO... AND TRY AGAIN.
Try this fix. It is an upgrade model from 8600, but the build is same and rollers are located in the same spots.
it is quite an undertaking for a novice to dismantle and remove pads and absorbers for cleaning and or replacing , but yes you should be able to, the ink is water soluble so with enough hot water you would be able to
HP Officejet Pro... | Answered on Nov 24, 2014
you will have to dismantle it somewhat ,easy to moderate difficulty
HP Officejet Pro... | Answered on Oct 10, 2014
In order to print on transparency film from a HP8600 all you have to do is load the paper rough side down with the white border going into the tray toward the back of the printer so that you can not see it when you look into the paper tray. The HP 8600 will auto-adjust for the film, that is why you do not have the option to select transparency like you did in the HP 8500
HP Officejet Pro... | Answered on Jan 31, 2014
Pull the plug out and put it back in
HP Office... | Answered 18 hours ago
You will need to take the side panels off to get to the circuit boards. The Main board is often on the right hand side when looking from the front
HP Office... | Answered 20 hours ago
It is probably a broken gear tooth in the FUSER
HP Office... | Answered 2 days ago
There will be one of several micro switches that detect when various doors hatches and flaps are open or closed. These are usually recessed behind small slots in the casing. Each will have a corresponding spike or flange on the appropriate door hatch etc. carefully examine each of the movable pieces and look for evidence of a small piece that may have broken off or a "socket" that does not have a "plug" to fill it. Test these by carefully feeding a non-conductive probe (just in case) into the port and feeling for a little bit of springy resistance. If you find one, fold some light card into a tube that fits snugly into the hole and depresses the switch. Close everything up and try the machine. Hopefully you will find the missing link, then it is just a matter of making a semi permanent plug that you can remove when you need to.
HP Officejet Pro 8600 e-All-in-One - multifunction  fax / copier / printer / scanner   color Logo
35 questions posted
Clive
Clive
View Most Popular
  • HP Office Equipment & Supplies
Most Popular Question
officejet 9600 vertical lines 4 in
  • Office Equipment & Supplies
