20 Most Recent
Samsung SCX 3405FW - Multifunction fax / copier / - SCX-3405FW/XAA Questions & Answers
Samsung scx3405f compatible toner
hello . i have a samsung scx-3405f and i have been refil the cartrige ... after i refiled my multifunction machine say on the display "Not Compatible toner cartrige". i donn`t know what to do to him because i have buy a new cartrige and she tell me the same thing. please answer to
[email protected] ... tks verry mutch
I have a samsung C410W printer which keeps on flashing red and will not print. Help
Samsung printer C410W. Red light flashing.Checked paper paths; checked cartridges (nothing lower than 85%); removed and returned cartridges; checked back panel paper path. Still flashing red.
Technician's Assistant: Have you tried running your printer's self-cleaning cycle? (Sometimes you have to run this several times to see results.)
Is the self-cleaning prompt in the Easy Printer Manager?
Technician's Assistant: Have you tried wiping down the metal contacts on your printer and cartridges?
I have now wiped them
Technician's Assistant: Anything else you want the Printer Expert to know before I connect you?
How do I start the self-cleaning cycle?
I can't show ip address of printer samsung ml3312nd
In Windows, you can use the Control Panel to find the printer's IP address.
- Go to Settings > Devices > Printers and Scanners.
- Find your printer in the list, click on it, and select Manage.
- Click on Printer Properties.
- In the General tab, find the Location field. Your printer's IP address will be located in it.
For MAC OS click the Apple sign and locate printers.
