20 Most Recent
Nikon Coolpix P80 10.1MP Digital Camera with 18x Wide Angle Optical Vibration Reduction Zoom Black Questions & Answers
My zoom will not come out, just clicks trying to come out.
Stuck zoom is the most common failure mode for a digital camera. Some
common error messages that might show up on the LCD's of cameras with
this problem include "E18 lens error", or "lens error, restart camera".
Some cameras might show nothing at all, but merely make a beeping noise
as the lens goes out, then in, then the camera shuts off. Sometimes the
lens won't even move.
The problem is actually quite common throughout all camera
brands. Usually it's sand or grit interfering with the lens extension
mechanism. Or the camera's been dropped with the lens extended. Or the
camera has been powered on, but the lens had been blocked preventing its
extension. Or the battery ran down with the lens extended.
A camera owner that suffers this problem may have no recourse for
having the camera repaired. Many camera makers will not honor repairing
this problem under warranty as they claim it is due to impact damage to
the camera, or sand or debris getting into the lens gearing mechanism
(neither of which is covered under warranty). The quoted repair cost is
usually close to or more than what the camera is actually worth.
This part can be easily replaced in most cameras.The following video shows how to open a Nikon Coolpix P80:http://www.desmontalo.com/?p=277
Just bought Nikon p600 and cant connect to WiFi help
U need to download nikon wmu software from google playstore or appstore. Then start wifi of ur camera and then start wifi connection in ur mobile.select "nikon p600" in wifi setup.when connected, start application named "wmu" in ur mobile.wait for the connection.after few seconds wifi connection will be established.hope this would help u!
My Nikon b500 Coolpix won't turn on just flashes green
It flashes green when it is basically on but in a sub mode that I'll call CHARGE MODE. If it is flashing that means the battery is charging. I suggest to let it continue to charge until it stops flashing and then remove the charger connection. When the camera is sitting all by itself with nothing connected you can then turn it on.
The screen on my Coolpix 500 looks like a chemical was poured on it. It is not scratched, what can I do
Is it the screen, or the screen protector ? If the latter, just remove it and replace it. If it is the actual screen, first of all try a lint-free cloth barely dampened with distilled water, and test it on a corner, see if that works. On no account get the camera wet. If that is unsuccessful, try adding a very little diluted washing-up liquid, and try again. Should that not succeed, I would advise taking the camera to your local repair facility for their expert advice.
