20 Most Recent
Sony Ericsson S710a Questions & Answers
256mb memory stick duo on s710a
the max the phone can handle is 256mb. 128mb chip and what the phone comes with. dont bother wasting money to try i already did this and you cant get around it
Help
the hardware built into the phone can only handle up to 128mb giving you a total of 256mb including phone memory. i found this out the hard way too.
Codes
How are we suppose to know them? Those are codes you set yourself.
No power s710a
First off, is it showing any source of power? If no lights are turning on, check to make sure the battery has a good connection to the pins. Most likely it is a pinched wire inside the case. You will have to reopen the case and move the wires around to make sure they are no longer pinched. Unfortunately, you may have damaged circuitry. If you attempted to power on the phone before rice drying it, then most likely you did, and thats why it will not power on. I suggest rice drying it, after about two days, place the device on a charger. If the red light does not come on after a few hours of charging, the phone is dead, sorry.
Won't turn on S710a
Your problem is this phone is equiped with a 23-44 pressure sensor, let it set for 4 or 5 days to reset. thats what i did, oh take out the batt.
