20 Most Recent Schwinn Airdyne Ad4 Upright Bike Questions & Answers
Error: tone when changing schwinn airdyne computer battery?
There could be a few reasons why you are hearing an error tone when replacing the batteries in your Schwinn Airdyne computer. Here are a few possibilities:
  1. The batteries may not be properly seated in the compartment. Make sure that the positive and negative terminals are facing the correct direction and that the batteries are fully seated in the compartment.
  2. The batteries may be dead or low on charge. If the batteries are old or have not been used for a long time, they may not have enough charge to power the computer. Try replacing the batteries with new ones to see if that resolves the issue.
  3. The computer may be damaged. If the error tone persists even after replacing the batteries with new ones, there may be an issue with the computer itself. In this case, it may be necessary to have the computer professionally repaired or replaced.
It's also worth noting that some models of the Schwinn Airdyne may have a "low battery" warning feature that sounds an alarm when the batteries are running low. In this case, the error tone may be a normal part of the bike's operation and not necessarily indicative of a problem. I hope this information is helpful. Let me know if you have any further questions or need more assistance.
12/22/2022 11:10:11 PM • Schwinn Airdyne... • Answered on Dec 22, 2022
0answers
I Need Console for 1988 Airdyne
The age of the machine is not as big of a replacement parts hinder as is Schwinn going through so many buy outs since 1988. One of the best exercise repair parts on online is FitnessRepairParts.com. They have consoles which are similar to your generation of machine for 170.00 - 240.00Otherwise schwinn was most recently owned by Nautilus/Bowflex/LAMAR fitness and they may be able to help through their website. Sorry, I don't have a great source of imformation to help with. I repair Schwinn exercise and it has become very hard to find parts recently as the new generation of AEROdynes are very different. Although, up until maybe 1-2 years ago, nothing had changed for 30 years. Alternatively, search craigslist and ebay. You may have to buy an entire unit to get the part you desire. Often they have a drive mechanism worn out which devalues them to the seller, but has minimal to do with your search.Good Luck.
1/8/2013 12:21:01 AM • Schwinn Airdyne... • Answered on Jan 08, 2013
Older schwinn airdyne manual
go to www.fitness.manualsonline.com or www.iconservice.com or www.retrevo.comGod bless you
7/23/2012 2:03:24 PM • Schwinn Airdyne... • Answered on Jul 23, 2012
Schwinn airdyne computer battery
it may need to be calibrated. Call schwinn or Treadmill Doctor at 800-750-4766 to walk you thru the calibration.
7/13/2012 3:03:05 AM • Schwinn Airdyne... • Answered on Jul 13, 2012
Where does the electric plug attach for the schwinn 220 recumbent bike
https://www.manualslib.com/manual/571857/Schwinn-220-Recumbent-Bike-2012-Model.html#manual
9/2/2023 1:43:05 PM • Schwinn Exercise... • Answered on Sep 02, 2023
Error 3 (E3) on Schwinn 240 recumbent bike. How
No speed/RPM reading, Console displays "E3" error code
Check data cable integrity All wires in cable should be intact. If any are cut or crimped, replace cable.
Check data cable connections/orientation, insure cable is connected securely and oriented properly. Small latch on connector should line up and snap into place.
Check magnet position (requires shroud removal) Magnet should be in place on flywheel. If no magnet is present, replace the flywheel or the entire base unit (if unable to replace flywheel).
Check RPM Sensor (requires shroud removal) RPM sensor should be aligned with magnet and connected to data cable. Realign sensor if necessary ( 1/8" clearance between sensor and flywheel) if still error 3 then check the sensor with a multi meter unplug sensor leads attach meter to sensor connectors. Have someone by hand rotate the pedal while you observe the multi meter opening and closing the internal sensor circuit if no change in meter readings then replace the sensor.
3/17/2023 1:02:26 AM • Schwinn Exercise... • Answered on Mar 17, 2023
Schwinn recumbent bike 240 has E3 error code. Does not display speed, rpm or calories
My RPM sensor was defective and I replaced it with a similar one from ebay and that did the trick: Horizon Tempo Treadmill RPM Speed Sensor Reed Switch 2 Terminal Wire 002267-B (flat version)
3/17/2023 1:00:15 AM • Schwinn Exercise... • Answered on Mar 17, 2023
My Airdyne AD-6 crank arms are ~45* apart, not 180* Can they be adjusted?
It is possible that the crank arms are not seated correctly on the bottom bracket spindle, causing them to be misaligned. Try removing the crank arms and re-installing them, making sure that they are properly aligned with each other and with the bottom bracket spindle. If that doesn't work, there may be an issue with the bottom bracket itself, in which case it may need to be replaced. You can also check the manual for your Airdyne AD-6 to see if there are any specific instructions for adjusting the crank arms.
2/25/2023 7:45:16 AM • Schwinn Exercise... • Answered on Feb 25, 2023
Schwinn Airdyne AD6 clicking noise?
not a car , moved yah./
12/11/2022 6:50:54 PM • Schwinn Exercise... • Answered on Dec 11, 2022
Schwinn 701S Home Gym. How to assemble cables please?
Here are all the manuals and the manuals usually have the assembly instructions at the beginning. https://www.schwinnfitness.com/manuals.html It is available here at moderate cost ask the maker first. https://www.fitnessrepairparts.com/m/cart/ViewItem/13006172 ..
6/19/2022 12:10:30 AM • Schwinn Exercise... • Answered on Jun 19, 2022
2answers
ASSEMBLY INSTRUCTIONS FOR HOME TRAINER 730
Always consult a personal trainer for assembly instructions. It's interesting how a fit partner can help you assemble almost anything. If anyone is interested in finding out more, please refer to the following fitness specialists. They are true professionals. https://busybeefitness.ca/fitness-partner-toronto/ personal-trainer-toronto-jeimvor1n0gozo1hzllrbhlx-1-0.jpg
12/21/2021 9:44:31 AM • Schwinn Exercise... • Answered on Dec 21, 2021
How do you change the battery on Schwinn 430 elliptical? Where are they located?
Did you check the wheel? Usually it's under the wheel
4/20/2021 10:21:56 AM • Schwinn Exercise... • Answered on Apr 20, 2021
I have a Schwinn Personal Trainer 700. How heavy are the weights? What is the highest weight it can be set at?
sorry no clue as never needed a weight set to keep me fit
4/17/2021 1:44:15 PM • Schwinn Exercise... • Answered on Apr 17, 2021
Replace battery schwinn model 430 eliptical
Schwinn® 430 and Journey 4.0 Elliptical Fitness ... - Nautilus
download.nautilus.com > SCH.430.SM.EN.pdf
PDF Roller Wheel Disc (older models only). 48. 15 ... change between "BIKE" and Elliptical ("ELIP"). 9. ... Replace the Brake Assembly on the Schwinn® 430/470.
assembly manual / owner's manual - Nautilus
download.nautilus.com > AM_OM > Schwinn > SCH.4...
PDF Manual en Espa?ol Latino Americano: http://www.schwinnfitness.com. 430 / ... If replacement parts are necessary, use only genuine Nautilus replacement parts and ... PEDAL TO CONTINUE (if a bike) / STRIDE TO CONTINUE (if an elliptical).
Replacing The Console Batteries - Schwinn a40 Owner's ...
www.manualslib.com > ... > Owner's manual
The Machine Type switch (N) on the Console is preset at the factory to B (bike) or E (elliptical). If you replace the console,. it will possibly be necessary to set the ...
How to Replace an Elliptical Console - YouTube
www.youtube.com > watch 0:42 This video from Sears PartsDirect shows how to replace a console on an elliptical. ... Precor EFX 546 ... May 22, 2015 · Uploaded by Sears PartsDirect
12/5/2020 4:38:47 PM • Schwinn Exercise... • Answered on Dec 05, 2020
420 elliptical. What does E1 error code indicate?
check out the attached link
11/3/2020 3:25:03 AM • Schwinn Exercise... • Answered on Nov 03, 2020
Where are the batteries on a Schwinn 420 elliptical
I have attached the manual for the same.Go through it to find all details
11/3/2020 3:24:14 AM • Schwinn Exercise... • Answered on Nov 03, 2020
Schwinn Airdyne Ad4 Upright Bike Logo
8 questions posted
Top Schwinn Exercise & Fitness Experts
john h
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Schwinn Exercise & Fitness
Most Popular Question
older schwinn airdyne manual
  • Exercise & Fitness
