20 Most Recent
Olympus E-pl1 Pen Digital Slr Camera w/ M. Zuiko 14-42mm Lens Black Questions & Answers
My pl1 camera has blurred pictures but when lens taken out, its ok.
Are you using an auto-focus m4/3 lens? I have about 20 lenses for this camera and only 1 of them is an auto-focus m4/3 lens. I have an adapter so I can use my 4/3 lenses on it in auto-focus mode along with other various mounts (including cctv) that do not support auto-focus. So if you are using a non-auto-focus lens, you will need to manually focus the pictures.
If you are certain it is an auto-focus lens, are you sure you have it set to auto-focus?
What settings do you have your camera set to (aperature mostly is what I'd like to know)? Try adjusting your aperature to be small (to increase your DOF).
Also what lens are you using and what is your focal distance? It could be your lens has a larger or shallower focal distance than what you are trying to achieve (like a macro lens doesn't work that great for landscape photography or a telephoto lens doesn't work great for macro photography).
Last thought: is your lens or sensor dirty? A dirty lens can cause focusing issues if it is REALLY dirty and a dirty sensor can too (sensor is a bigger pain to clean. I strongly recommend taking it to the pros as they scratch really easily). Dirty lenses can be cleaned with a blower and a lint free cloth and rubbing alcohol if those 2 things don't clear it out.
E-pl1 service manual
I don't have the manual from this camera. But when I have this problem I look on ifixit dot com (to prevent me from reading this stupid code I won't place the name) There you find lots of help, when toy want to repair a modern electronic thing, including camera's
My Olympus VR-340 is not working.
Locate the reset button on your camera, usually found in the battery compartment. Press and hold the reset button for a few seconds, then release it. This action may help resolve any software glitches causing the issue. myreminiapk.com
WHEN I TURN MY OLYMPUS ON IT GOES RIGHT TO "ZOOM ERROR" THEN SHUT OFF. ANY SUGGESTIONS?
When your Olympus camera goes straight to "Zoom Error" and then turns off, it is likely that there is an issue with the camera's lens mechanism. Here are a few things you can try to troubleshoot the problem:
- Turn off the camera and remove the battery and memory card. Then, wait for a few minutes before re-inserting them and turning the camera back on.
- Gently move the lens back and forth with your fingers to see if it can be moved and if it is stuck.
- Use a can of compressed air to blow dust and debris out of the lens mechanism.
- Check the lens for any physical damage such as cracks or dents.
- Try using the camera without the zoom function to see if it still turns off.
- If none of the above steps resolve the issue, it may be best to contact Olympus customer support for further assistance. They will be able to diagnose and fix the issue or tell you if a repair is needed.
It's important to keep in mind that the Olympus camera is an older model camera, which makes it harder to find replacement parts and professional repair services. If the camera is still under warranty, you may be able to get it repaired or replaced by the manufacturer.
My olympus sz 14 camera shows Zoom error on the screen when I turn it on and then turns off immediately. I bought a new battery a d charged the camera but it continues to shut off.
The "Zoom Error" message that appears on your Olympus SZ-14 camera's screen when you turn it on, followed by the camera turning off immediately, could be caused by a problem with the camera's lens.
- Try gently tapping the camera on a flat surface to try and realign the lens.
- Check the lens for any dirt or debris that may be blocking the movement of the lens. Clean the lens with a soft, dry cloth.
- Check the lens for any physical damage like dents or cracks.
- Contact Olympus customer support: If you have tried all the above steps and the camera is still not working, it may be best to contact Olympus customer support for further assistance. They will be able to diagnose and fix the issue or tell you if a repair is needed.
It's important to keep in mind that the Olympus SZ-14 is an older model camera, which makes it harder to find replacement parts and professional repair services. If the camera is still under warranty, you may be able to get it repaired or replaced by the manufacturer.
How to transfer photos taken by an Olympus Camedia C-1000 L to a computer?
To transfer photos taken by an Olympus Camedia C-1000L camera to a computer, you can use the following method:
- Connect the camera to the computer using a USB cable.
- Turn on the camera and set it to the "PC" or "Computer" mode.
- On your computer, a new drive or a pop-up window should appear, indicating that the camera has been recognized.
- Open the drive or window and navigate to the folder where your photos are stored.
- Select the photos you want to transfer and copy them to your computer by using drag and drop or "Copy" and "Paste" functions.
Alternatively, you can use the Olympus Camedia Master software that came with the camera to transfer photos. Once connected and the software is open, you will be able to see the camera's content, then you can select and transfer the photos to your computer.
It's important to keep in mind that the Olympus Camedia C-1000L is an older model camera, which may not be compatible with the latest version of computer operating systems, so it's recommended to check the software and the operating system compatibility before transferring the photos.
