20 Most Recent
Canon iRC2380i Questions & Answers
E000990-0000
E990 Error in the waste toner shutter0000 When the output of the waste toner shutter opening and shutting detectionsensor doesn't become "H" when it WMUPR period after the sleep returns aftereight hours or more pass, the door opening and shutting is detected or mainpower switch turns on.- Check that the drum unit is properly installed- Replace the waste toner shutter sensor
When printing black dots appear chaotic, over the entire sheet of paper. What to do?
If the black dots appear on every sheet of paper it could be the fuser unit is wearing out or the drum unit. The way to check that is to stop a print half way through and remove the paper. If they are not there before the fuser unit but after it then it will be the fuser. Or if they are there before the fuser unit it will be the drum unit. If it they only appear specfic to one source then it is likely to be the source of the document. IE copying - check the optical area (scan glass etc). If on incoming Faxes it may well be the sender that has the problem and is just transmitting them to you. Hope this helps.
Removing the optical part with canon irc2380i
Dear Sir,
Please clean the cleaning blade and try printing a test page if that does not fix the problem then please try to replace the 'Laser beam scanning unit' But before replacing please try to clean the unit with soft cloth.Hope this would help
kind regards
