20 Most Recent Beverage-Air MT45 Beverage Cooler Commercial Questions & Answers
Is It A Cooler or a Freezer?
With no heaters or defrost timer, it is most likely not a freezer unless someone removed all that. As best as I can tell, I can not find anything that equates to the temperature and pressures you related to. It could be either low on Freon or the R-12 has been removed and an alternate Freon installed to replace it. Hope this helps.
1/16/2018 1:15:56 AM • Beverage-Air... • Answered on Jan 16, 2018
I have a 2 door
In general, these units are not to be exposed to temps over 80 degrees. Anything above this and it will struggle to keep temp.
1/16/2018 1:09:16 AM • Beverage-Air... • Answered on Jan 16, 2018
2answers
Looking for a temp control for a bev air mt45 that
Beverage Air does make a separate thermostat for use with wine storage.
Click Here to be taken to the beverage air website for part distributors.
2/28/2016 8:18:41 PM • Beverage-Air... • Answered on Feb 28, 2016
2answers
I replaced th compressor on my Beverage Air cooler
process of replacing compressor on beer cooler. Hope that helps.
8/25/2015 1:09:42 AM • Beverage-Air... • Answered on Aug 25, 2015
Model mt 45-v trouble shooting can not get cool
FREEZER /FRIDGE NOT COOLING: Optimum refrigerator temperature at or below40° F(4° C). The freezer temperature should be0° F(-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these Check ur cold control thermostat, ur thermistors in both fridge and freezer ( they should be checked for both ohms and for amount of current being put out as per ur model ), ur air flow vent from freezer to fridge.( to make sure it opens and closes without any restrictions) On thermistors check for A close circuit and amount of ohms not just an Ohm reading. As per ur model. Most should atleast show 1200 ohms. Also Check door seals for leakage. Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. FAN check to see if it is operating or restricted A fan that is not blowing or restricted will not circulate the cold air properly. Often, the first thing that folks do when their refrigerator starts to feel warm is turn both controls on the coldest settings.This is exactly the WRONG thing to do.Turning the cold control to the coldest settingwillkeep the compressor running longer and make lots of cold air. But turning the air door to the coldest settingclosesthe airway to the food section. Lots of cold air is made, but most of it stays in the freezer section, and the food section actually getswarmer. Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator. May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad? Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next. Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance.. THE COMPRESSOR: If you hear a clicking sound coming from the back of your refrigerator/freezer, then the problem is most likely the compressor, relay and or capacitor is overheating or not getting proper power and will not start.The compressor is the component on your refrigerator that allows your refrigerator to cool. If this component is not working properly your refrigerator will stop cooling. Most of the time the compressor is not the component that has failed. To check ur compressor with multi meter: Disconnect and remove the relay and capacitor from compressor, some located next to compressor in a casing. You wills see 3 prongs coming out of compressor. 1 goes to ur srtart winding, 1 goes to ur run winding and the center goes to ur ground. Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms. Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity Lastly you should also check ur THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 13000 ( give or take 150 ohms) ohms is required. Read more:http://removeandreplace.com/2013/10/31/fix-refrigerator-freezer-wont-cool-freeze/#ixzz3WDEo5NDJ REMEMBER GOD IS THE REASON FOR GOOD ADVICE" Refrigerator Is Not Cooling What To Check And How To Fix
6/20/2015 1:28:20 AM • Beverage-Air... • Answered on Jun 20, 2015
Charge refrigerant into system
Before you put gas in the system you need to find the leak or is it just something you want to try? These systems don't have room in them for extra gas. Check to see that the condenser is clean and the fan is running when the compressor is on. The manufacturer doesn't install access valves on systems like they used to and generally valves will have to be silver brazed into the system by a refrigeration tech. Hope this answers your question and good luck.
10/18/2014 6:16:38 AM • Beverage-Air... • Answered on Oct 18, 2014
Drain tube clogged in commercial freezer
Try using a turkey baster with warm water to push the blockage around and break it up. Hope this helped and good luck.
10/18/2014 5:59:30 AM • Beverage-Air... • Answered on Oct 18, 2014
0answers
Where does the temp control tube go when replaceing temp cont. on mt45 cooler
how does the cooler door adjust
1/10/2014 1:49:00 AM • Beverage-Air... • Answered on Jan 10, 2014
2answers
My beverage air MT45 is
bad thermostat sound like its not shutting off.
1/10/2014 1:48:09 AM • Beverage-Air... • Answered on Jan 10, 2014
Beverage Air Model MT 45
Hello, We specialize in cooler gaskets but also sell hardware and accessories like shelves, latches, and hinges. If you provide us the model and serial we can locate the OEM shelf you need to replace and provide a price below List price. We'd be more than happy to help. Email us your unit's info at [email protected] or call us at 855-288-2259 Thanks - Matt www.coolergaskets.com
1/3/2014 2:09:36 PM • Beverage-Air... • Answered on Jan 03, 2014
0answers
Wiring diagram
Be the first to answer 12/8/2013 10:33:56 AM • Beverage-Air... • Posted on Dec 08, 2013Be the first to answer
MT45 0705I02 R12 not cooling, motor in bottom not working as well.
I had the exact same problem. The condenser fan in the bottom should run all the time. The entire condenser unit (compressor, coils and fan) sit on a metal tray that may be rusted to the bottom of the unit so a few taps from a hammer from the back may be needed to slide it forward. Once you can get to the fan, check the wiring. On mine the spade plug had rusted away. Follow the wires from the fan to a small box on the side of the compressor. Make sure the fan wires are securely connected to the terminal block. There are two male spade connectors that provide constant 120v. They point up. Make sure there is power and the fan motor is connected.
8/8/2012 2:45:21 AM • Beverage-Air... • Answered on Aug 08, 2012
Beverage-Air MT45 Beverage Cooler Commercial Logo
45 questions posted
Top Beverage-Air Refrigerators Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Jorgie  the...
Jorgie the...
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Beverage-Air Refrigerators
Most Popular Question
model mt 17 54 will not cool
  • Refrigerators
