20 Most Recent HP Officejet Pro 8500A Wireless All-in-One Inkjet Printer Questions & Answers
try uninstalling the associated software, perform a disk cleanup and a defrag and then reinstall . This may make a difference. If your computer has slowed down generally try installing and using CCLEANER to sanitize your hard disk. Unless the issue is related to USB issues or the hardware itself, or a broken/damaged O/S installation this procedure may resolve the problem
HP Officejet Pro... | Answered on Oct 26, 2015
Pickup rollers can be easily replaced if you want to try that first. But the other noises could point to stripped gears or a different problem internally
HP Officejet Pro... | Answered on Feb 13, 2015
check your margin settings.
HP Officejet Pro... | Answered on Sep 10, 2014
Go to the Google Market and download an apps called HP All-in-One Remote and install it in your Samsung Note 3.
Then while your Note 3 and HP Officejet were in the same wi-fi network, your Note 3 should be able to detect the HP printer. Then you could select which documents to print and whether B/W or color.
HP Officejet Pro... | Answered on Jul 26, 2014
Go to www.hp.com/support and let HP detect and install the unit automatically.
HP Office... | Answered 51 minutes ago
Perform the Reset Life Counters utility as follows:
1. In the Service Utilities submenu, scroll to Reset Life Counters and press OK .
2. Select Reset Maintenance Kit usage to reset the Life Counter for all parts included in a
Preventative Maintenance Kit (PMK).
You can choose from the following Preventive Maintenance Kits:
? Preventive Maintenance Kit 1 (PMK1). See Preventive Maintenance Kit #1 for 44-in models
(CH538-67024) on page 406 .
? Preventive Maintenance Kit 2 (PMK2). See Preventive Maintenance Kit #2 (CH538-67040)
on page 407 .
NOTE: For more information about the counters that are reset, See Preventive Maintenance
on page 400 .
It is also advisable to check the status of the Life Counters related to the other Preventive
Maintenance Kits to avoid multiple trips to the customer.
3. Select Reset usage counters to reset the Life Counter of a single part.
? Tubes and Trailing Cable
? Scan-Axis Belt
? Scan-Axis Motor
? Left Spittoon
? Right Spittoon
? Full Bleed Foams
? Carriage
? Service Station
HP Office... | Answered Yesterday
Open the lid it's not an ADF flatbed scanner only.
Or download drivers from here to scan to computer
https://support.hp.com/us-en/drivers/selfservice/HP-PSC-2350-All-in-One-Printer-series/390347/model/390353
HP Office... | Answered 2 days ago
  1. Start -> Printers and Faxes, or Start -> Control Panel -> Printers and Faxes.
  2. Right-click the printer name, and left-click Properties.
  3. Click the Ports tab, and widen the first column which displays IP address of the printers.
is it laptop or printer. it it is a laptop and if it is windows 10 just goto display setting and give the font size with persentage.
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP-Envy-4500-Printer-Font-Size/td-p/6369207
HP Office... | Answered 3 days ago
The 49 error codes on HP LaserJet printers are communication error codes. ... Try turning the printer off, and unplug it from the computer (and network), clear any pending jobs from the print queue on the computer, then reboot the printer.
HP Office... | Answered on May 19, 2019
HP Officejet Pro 8500A Wireless All-in-One Inkjet Printer Logo
21 questions posted
Clive
Clive
Thomas F. Schneider
View Most Popular
  • HP Office Equipment & Supplies
Most Popular Question
scanning function become incredibly
  • Office Equipment & Supplies
