20 Most Recent
Nikon 26304 Coolpix S4300 Questions & Answers
Why my coolpix s4300 will not charge
How old is the battery in the camera? Most rechargeable batteries will eventually lose their ability to charge. Usually one cell of the battery fails and the battery never reaches full charge. If the battery is more than a year old, replace it. The Coolpix S4300 uses the EN-EL19 and suggested retail price of $41. If you have tried a new battery, I would suspect a problem with the charging port. That isn't something I recommend fixing yourself. I hope this helps. Cindy Wells
Just bought Nikon p600 and cant connect to WiFi help
U need to download nikon wmu software from google playstore or appstore. Then start wifi of ur camera and then start wifi connection in ur mobile.select "nikon p600" in wifi setup.when connected, start application named "wmu" in ur mobile.wait for the connection.after few seconds wifi connection will be established.hope this would help u!
My Nikon b500 Coolpix won't turn on just flashes green
It flashes green when it is basically on but in a sub mode that I'll call CHARGE MODE. If it is flashing that means the battery is charging. I suggest to let it continue to charge until it stops flashing and then remove the charger connection. When the camera is sitting all by itself with nothing connected you can then turn it on.
The screen on my Coolpix 500 looks like a chemical was poured on it. It is not scratched, what can I do
Is it the screen, or the screen protector ? If the latter, just remove it and replace it. If it is the actual screen, first of all try a lint-free cloth barely dampened with distilled water, and test it on a corner, see if that works. On no account get the camera wet. If that is unsuccessful, try adding a very little diluted washing-up liquid, and try again. Should that not succeed, I would advise taking the camera to your local repair facility for their expert advice.
