20 Most Recent
Nikon Coolpix S3300 Questions & Answers
My wonderful Coolpix recently seems to be letting in too much light when I go to take a picture..worked fine before
It is mostly due to changing the exposure compensation. You can change it from +2 ....0 ....... -2. +2 Makes it Brighter while -2 makes it darker... On the back of the camera you will see an OK button surrounded by a disk that on the right side shows [+/-]. You use this to change exposure compensation. When you get the camera READY to take a photo you can use that [+/-] button. When you push it you can adjust it to zero (o) normal or to make it lighter or darker.
Pc will not recognize coolpix s3300 camera
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa (
http://picasa.google.com ).
How do I delete videos
The videos should be showing up just like a photo does and when the video is brought up using the replay button, just use the delete menu to delete it.
Camera doesn't work anymore....is dead!
Call Nikon Service at 1-800-645-6687 between 9AM and 8PM EST, Monday to Friday. They will provide you with the information you need to get it repaired along with approximate cost.
What is a small dark area appears on viewfinder and photos?
is it only the view finder or does it appear on the photo as well because if it the view finder then it is the screen and if it is on the photo as well then its most likely the lense and once you have deterined this then you can know if it is just dirty or if the screen needs replacing
Why no snap shot are taken when flash is on?
then the best thing to do is to take it back to the place you bought it from and let them sort it out for you as when you open the item it voids that warrenty and then you will have to pay for any repairs needed
Download driver for nikon coolpix s3300
Do you really need a driver?
Nikon coolpix s3300 turn on LCD
Coolpix s3300 does not have any other viewfinder, your LCD panel is your only viewfinder. By default it cannot be turned off.
Please provide more informations so that I can help you.
