20 Most Recent
Singer 4411 Sewing Machine Questions & Answers
How do you open the bobbin compartment on a Singer 4411
Here are the steps to open the bobbin compartment on a Singer 4411 sewing machine:
- Turn off the sewing machine and unplug it from the power outlet.
- Locate the bobbin compartment on the front side of the machine, below the needle plate.
- Hold the handwheel on the right side of the machine with your right hand and turn it towards you (counterclockwise) until the needle is at its highest position.
- Slide the bobbin cover release button, located to the right of the bobbin compartment, to the right and hold it there.
- The bobbin cover should now pop open. Gently pull it towards you to fully open the compartment.
To close the bobbin compartment, simply push the bobbin cover back into place until it clicks and locks into position.
Adjust timing on singer
what timing are you talking about? If is needle timing, remove the left cover of the machine and try adjusting the timing from there . If the problem is more complex, you will have to remove the bottom of the machine. It's not difficult but, if you need any help, I will guide you step by step.
How to oil a singer 4411 sewing machine
you oil it in the center of your bobbin case, also theres a small pad like thing just above your needle , there as well as inside your threading area where the spring is
Singer 4411
You may have a timing issue with your sewing machine.
Hand wheel will not move
it would be a good idea to have the machine checked to see if thereis a damaged part in the machine.
