20 Most Recent
Legacy LDN7U Car Video Player Questions & Answers
Won't play mp4 files
does your video player support the Mp4 video files? if it can,you can check the resolution is whether right or wrong.if it can not,just use a video converter to convert the videos to the right format for it.Here is the
Best video converter i have ever used.
Legacy LSW127 rms rating?
4000 watt amp that was 2-channel with 2000 watts peak and 1000 watts RMS per channel, when wired as 4-ohm, which is what the sub's ratings are based on. therefore the amp and sub configuration were a perfect match, however approximately 1/2 an hour into driving with them i noticed a plastic/rubber burning smell and immediately shut off power to them. upon inspection both subs were blown and completely unusable. this leads to the conclusion that they were poorly rated and of poor quality materials, and i hereby advise that unless your going to run way under the limits, they are no good!
What ar the specs for a legacy LA420 600 w amp
This Legacy LA 420 amplifier features 400 watts of power, two channels (bridgeable), a two-way crossover, Mosfet power, 2 ohms stable, and THD less than 0.04%. The amplifier measures 10" x 9.5" x 2.75".
