20 Most Recent
Lenovo G570 Notebook Questions & Answers
How to crack/unlock the password set on sata port 0 ST9500325AS Lock on a lenovo G570
I will recommend to talk to the shopkeeper or the online site from where you have ordered your computer to resolve your problem if you have ordered it online then I will recommend to talk and call on the company number they provide help in the footer contact us link if you click that link it will redirect you to contact us page where you can talk to the company help and resolve your issue or else you can check on the header for the contact us page
Fn function key working
What are you trying to do that it's not working? If your trying to adjust brightness go to power plans and change settings there. Some settings don't allow changes in brightness in certain situations.
DVD drive not being recognized
go to control panel and use the utility system restore. Go to some date the computer was working and fix it. Otherwise, restar the computer HOLD the CTRL key +f2 or esc depend of your computer mark, and go to restore factory default and fix it.God bless you
Bluetooth
fConnecting a Bluetooth device (Select models only)If your computer has an integrated Bluetooth adapter card, it can connect to and transfer data wirelessly to other Bluetooth enabled devices, such as notebook computers, PDAs and cell phones. You can transfer data between these devices without cables and up to 10 meters range in open space.Enabling Bluetooth communications on your computer1Slide the integrated wireless device switch from the button .2Press Fn + F5 to make configuration.Note: When using a high power consumption USB device such as USB ODD, use the external device's power adapter. Otherwise, the device may not be recognized, and system shut down may result.Note:The actual maximum range may vary due to interference and transmission barriers. To get the best possible connection speed, place the device as near your computer as possible.Notes:•When you do not need to use the Bluetooth function, turn it off to save battery power.•You need to pair the Bluetooth enabled device with your computer before you can transfer data between them. Read the documentation supplied with the Bluetooth enabled device for details on how to pair the device with your computer
Print screen key lenovo laptop
The auto save facility is not enabled if u press PrtSc , after pressing this key, go to MS Paint and press Ctrl+V if there appears your printed screen ,, then its done....
Power on but no display no extrnal display
if you can hear the windows booting sound when you turn on the pc , then your screen needs to be replaced,,, othewise, please reboot the OS and check for the problem existance..
my LENOVE G570 screen just got broke last time while im watchin dvd.a crazy RGB shown-up and i dont know why!! then i start looking for "how to open a Lenovo G570 screen" then i came up with this http://www.youtube.com/watch?v=3FwSoAzEXswthen i start cleaning the surface using pressured air from my balloon maker. .then i remove the "jack" or whatever you call that. . and erase it with a pencil eraser then put it back!!when i open my loptop again!!it suddenly work!!
I forgget my password
Not enough information. You need to identify which password. Windows login(if so what version of windows) bios password, encryption password etc.
How to find my lap back up problem
Right-Clicking My Computer (or computer in the start menu) -->
Manage (you may have to have the proper user account to do this)
on the left column expand Storage and select disk management
Check to see if you have adequate space in your main partition. You
should have lenovo_TOOLS (E:), Recovery (D:), aswell as 980GB Free in the
remaining partition [System, boot, Page file...etc] (usually C:).If you need any kind of technical assistance you can contact support cell at
http://www.vtechsquad.com/
