20 Most Recent
Beverage-Air 44.9 cu. ft. / 1271 liter Commercial Freezer KF48 Questions & Answers
How lpw of a temp. Can this freezer reach..and and
There are different models made for holding different products. Yours has a 1/3 hp compressor for above 20 degs. It may have 0 on the thermostat and may well pull down that far, but -20 would be out of it's reach. Where as it's sister model is made to freeze to below zero has a 3/4 hp compressor. Larger compressor for the lower temps.
Freezer problem kf 48
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Need to know what type of freon to use to recharge
Beverage air used R134a almost exclusively on refrigerators. The process is similiar to ac systems. You should weigh the charge in as per the data plate. Be precise as over or under charge can dramitically affect the performance of the unit. Hope this helps
Frezzing up
Be sure you have the defrost timer set for 4 defrost cycles and no less than 30 minutes each time.
Make sure doors close and seal tight.
Verify that the defrost heaters work.
Sit and time a defrost cycle. It could be terminating early, prior to the coil being completely cleared.
If it is frost on the coil, could be an air leak or high humidity.
If it is icing, it is a defrost problem.
Start here and let me know.
Good Luck!
KF48 Beverage Air Freezer permently stuck on "defrost."
Unplug the fridge overnight and defrost it completely. Ensure the thermostat is properly set.
If it does not restart normal function after you plug back, then there may be a fault concerning the digital control, in that case call the number listed on the owner manual.
Thermostat differential on a Bev air ef48-1as
Having to manually defrost an automatic defrost system tells me there is a problem with your defrost timer. Most Beverage-air freezers have a Paragon timer. There are two dials on these timers. An inner and outer dial. On the inner dial is an arrow to indicate the direction of rotation as counter clock wise. On the inner dial is a copper pointer indicating duration of the defrost cycle.
Observe the copper pointer, no movement indicates that the timer is bad.
