20 Most Recent
Creative Labs Gigaworks S750 Computer Speakers Questions & Answers
All I need is the control pod for the Gigaworks S750
I had an extra one but I sold it. According to creative labs they do not sell any replacement parts for the speaker systems. The best suggestion that I can give is to check craigslist and ebay for the control pods.
I have a Creative Gigaworks S700 i have checked both fuses still no power to control box
Stupid question: does the sound still work? it could be the LED just died after continual use (rare, since they last a long time, but not uncommon). If not... it could be the controlling circuit board died. In which case, unless you have electronics repair experience, it would be probably more worthwhile to just replace the speakers, as pricey a model as it is.
Gigaworks S750
If you check the Creative forums there is a thread there where a few people have started to fix problems like this permanently and they have helped quite a few people fix their problems. I would only suggest checking it out if you have any electronics experience (soldering, and basic troubleshooting minimum). Otherwise I would send it back but keep in mind that this is one of a few common problems with the S750's and you are likely to have other problems in the future unless you take measures to fix the problem that creative has not.
I would also like to point out that your problem would be a short on one of the amp boards after the power regulators, very likely one of the STA575 amplifier ICs. Those are not easy to find but it is possible to find replacements.
Can i attach a 3.5mm 2 my speaker
I don't know what your skills are, But if it is a cable with two separated wires, that was connected with a 3,5 mm phone plug not that many can go wrong, as long as you put bot wires to a separate connection point of the plug. Be aware one of the wires is supposed the plus the other minus or common. If you revers this, it could change the case in the speaker, but perhaps you won't hear that.
On the one of the wired often is a white spot or line that can be seen over the complete length. That is how you can see the difference between + and -
If in the cable are a lot of wires, perhaps you should not start at all.
Don't make a shortage, to avoid you blowing up the amplifier.
Success
Cambridge Soundworks Gigaworks S750 I left the
To make these your default speakers, you will need to do the following 1. Find the volume control icon on the bottom right portion of your screen 2. Right click the icon 3. Select change default 4. Cycle through the options until you see the logitech speakers as an option 5. Select this new option 6. If you still do not see the logitech speakers then you need to reinstall them with the provided software. If you do not have software, download it for free from logitech.com
