Yes, it will set it all back to factory defaults
to set the security again on the router
Support site for D-Link is here
http://www.dlink.com/corporate/worldwideoffices/?redirect=/default.aspx
In principle:
Connect your PC to the router with a cable to one of the LAN connections - Now you need to Log into the setup of the router - to do that open a web browser, use Internet explorer (some routers setup pages do not work correctly with other browsers) In the browser address bar - http://192.168.0.1
Enter (admin) for the user name and also for the password.
Now you can goto the wireless section or secruity section and set the type of encyption to WEP, WPA, WPA-PSK etc and then make up your own password
On the PC
Double click on the wireless connection in the system tray (bottom right hand side of screen) and then connect manually to your wireless signal - you will be asked for the password you set in the router.
Now you are connected.
You may need to remove any old wireless profiles you have on the PC/Laptops
Wireless Profiles - Vista/Windows 7:
http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm
http://www.tp-link.com/support/showfaq.asp?id=214
- delete the wireless profiles
Start> control Panel> classic view> network and sharing center> manage wireless networks
Delete the profiles
you will then have to enter the wireless security key for any networks you connect to
Wireless Profiles - XP
http://www.tp-link.com/support/showfaq.asp?id=186
- delete the preferred networks
start> control panel> network connections>
right click on the wireless connection listed wireless networks tab in the preferred network list
click on each one and - remove button
