20 Most Recent
Vibe AC12 Car Subwoofer Questions & Answers
Sub keeps on sounding like a heartbeat and a blue
It sounds to me like your amplifier is getting caught in a loop-- the heartbeat is the subwoofer catching a surge of power from the amplifier. Make sure all of your connections are solid. If they are, try using the amplifier in another vehicle that is already set up for an amplifier. If it does not work, you may need to spring for a new amplifier.
My port plug (for the
plug pushed out due to any kind of air pressure this is not possible.But yes in some rare cases it has noticed that plug gets thrown out due to high voltage issues.In the unit there is a fuse and the power supply.If the fuse is weak or if the unit is receiving less power then required then due to internal circuit overheat the connections will get cut and due to this port plug gets pushed out.But this is seen in very rare cases.Just get the units fuse and voltages checked out to confirm the fault.A local electronic tech will be helpful to check the connections.
Thanks. keep updated for any more query.you can rate this solution
and show your appreciation.
How do u put videos on the go gear vibe
u need an additional conversion program for the GGV, It's video format is .smv. Since I bought it from a store, they got a conversion disk (include in the package) for videos and pictures. So, check your package of GGV, maybe u miss it.
I got a 2007 vibe and while it idle's I can hear a
With the vehicle running and condition is duplicated, open your hood and verify it is a radiator fan running. Radiator fans can appear to run continuously if the air conditioning is on. Otherwise the fan should cycle on and off keeping your engine in a specified operating temperature range. You didn't say if the vehicle was overheating or not so I assume it isn't and more than likely your A/C is on and your fan is running normaly. If you are running your hvac system in defrost mode your A/C compressor will run to dry the air in the vehicle and your fan will run.
If none of the obove applies then you could have an issue with a coolant temp. sensor circuit and you should take your vehicle in for service.
How to install the cables??
If you are looking to run your cables through the vibe to the doors and what not, it would depend if you have a door boot with wires running or a molex plug with connectors, if you have connectors on the door i would suggest you take it out carefully find a blank spot to drill through or push your wires to your door through. If its an after market deck White is your front left, grey front right.
also factory wires can handle a lot of power and run lots of current you can amplify them etc so if you want to run new wires you can but tacking onto your previous factory ones wouldnt hurt, same with rear but you would need to pull the drivers kick panels off and the running strip to run pieces to get to the back of the car and so on, for true performance if running an amplifier, try to run signal cables on the opposite side of the car from power and grounds for less singal disruption.
Connection of wiring for rear
should be only two wires there for each side. are you replacing factory speakers with different non factory speakers ?
Location, exact location of the fusebox under the
You have to crawl under the steering wheel and look under the dash board. There is a small black box that can be seen with the assistance of a flash light. The cover of the small box comes off, exposing the fuses.
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
