20 Most Recent
D-Link NetDefend DFL-700 Firewall Questions & Answers
How to connect basic
You have both equipments with the same ip address. Connect the PC to the firewall, login and change the IP first.
Exchange server access problem.
If your cisco vpn client is behind the natted device then you need to allow nat traversal in the head office firewall and if you connect the vpn client through data card it will connect,
Connection to ftp closed by remote host
this will not be a problem of your firewall. it will almost certainly be a password problem. ftp uses ports 20 & 21 but if you have disabled the firewall this cannot be the cause.
Unable to reset Dlink DFL 700 network firewall
To perform a factory reset using the reset button do the following:
Step 1: Make sure that the DFL-200/DFL-700 is on.
Step 2: Press and hold the button located on the back of the DFL-200/DFL-700 below the word Reset using a paper clip for 10 seconds.
Step 3: Release the button.
I have two different domains that are connected
This is an excerpt from a MS Technet page for error 53:
Resolutions: 1) if it is domain environment, check your WINS; 2) if it is peer-to-peer workgroup, enable NetBIOS over TCP/IP; 3) make sure the machine is running; 4) make sure file and Printer Share enabled on remote computer; 5) make sure client for ms networks is enabled on local computer; 6) make sure you type the correct name. 7) Make sure no firewall running or any security setting.
Pay close attention to #s 4 and 5 - I suspect XP pro might not be open enough.
Firewall is blocking incoming emails
Do you have an email server in place? If so, you need to setup port 25 for inbound access to the IP address of the email server. I would suggest that you don't allow all as that will open up everything and kind of negates the reason to have a firewall. Some ISPs block port 25 though and use port 587.
If you don't have an email server then the problem might be with your email client configuration.
Access
try
user : admin
pass : admin
Thanks
LAN
Is the McAfee Firewall blocking incoming requests (netbios probably)
Traceroute does not work
You have to allow the following:
ICMP type 8 (Echo) from your DMZ to the Internet (a.k.a outbound)
ICMP type 0 (Echo reply) from the Internet to your DMZ (a.k.a inbound)
This will be done by adding the rules in the firewall section of your DFL-700.
9815813107 tell me name and adrress
You can find the details of the operator and the state they belong to .the operators wont reveal the address and name of any mobile numbers only higher officials can only get those information.
In order to trace the operator name and state you can try this link
http://www.indiatrace.com/trace-mobile-number-location/trace-mobile-number.php
I hope this will help you if it does do rate the answer
Thank you
regards
lalith
