20 Most Recent
D-Link DI 804V (DI-804V) Router Questions & Answers
Router as cable modem
This answer is for a Dynamic and Static Cable connection (I.E. ATnT-BI, Cox, Adelphia, Rogers, Roadrunner, Charter, and Comcast).
Note: Please configure the router with the computer that was last connected directly to the cable modem.
Step 1: Log into the web-based configuration by typing in the IP address of the router (default:192.168.0.1) in your web browser. The username is admin (all lowercase) and the password is blank (nothing).
Step 2: Click on the Basic Setup tab. Dynamic IP Address is the default value, however, if Dynamic IP Address is not selected as the WAN type, select Dynamic IP Address by clicking on the radio button. Click Save and Restart.
Step 3: Click on the Device Status tab and verify that you have a solid link between the router and the modem.
If you do not have a solid link between the modem and the router follow the steps below:
# Turn the cable modem off (first)
# Turn the router off
# Leave them off for 2 minutes**
# Turn the cable modem on (first)
# Wait until you get a solid cable light on the cable modem
# Turn the router on
# Wait 30 seconds
** If you have a Motorola (Surf Board) modem, leave off for at least 5 minutes.
Step 4: Follow Step 1 again and log back into the web configuration. Click the Device Status tab . If you do not already have a public IP address under the WAN Ethernet heading, click on the DHCP Release and Renew buttons.
Setup Static Cable Connection
Step 1: Log into the web based configuration by typing in the IP address of the router (default:192.168.0.1) in your web browser. The username is admin (all lowercase) and the password is blank (nothing).
Step 2: Click the Basic Setup tab. Select the Static IP Address radio button and enter in your static settings obtained from the ISP in the fields provided.
Note: If you do not know your settings, you must contact your ISP.
Step 3: Click on Save and Restart.
Step 4: Click on the Device Status tab and verify that you have a solid link between the router and the modem.
# Power cycle the cable modem and router.
# Wait 30 seconds
Resetting the router
There are two ways to reset the unit back to the factory default settings.
Through the web-based interface:
Step 2: Click on the System Tools tab and go to the Load Default Settings tab on the left.
Step 3: Click on the Start button to proceed. This will now load the unit back to factory settings.
Note: The Device IP Address will be reset to 192.168.0.1 after loading the default settings.
Perform a hard reset:
Step 1: Power the unit off by unplugging its power adapter (from the unit, not the wall).
Step 2: Insert a paper clip into the reset pinhole. Press and hold the reset button with light pressure.
Step 3: Power the device back on by plugging it in. Continue to hold the reset button.
Step 4: Watch the lights on the front of the gateway. The status light and wireless light will power off. Once both lights are powered off release the reset button.
Step 5: The unit will reboot and now will be reset to default settings.
VPN
This example will demonstrate how to create a Virtual private Network (VPN) between two remote locations through the Internet. The VPN policy will use 3DES IPSec to securely send/receive encrypted data over the Internet. When the VPN tunnel is enabled, the two offices will virtually appear to be on the same local network.
This example will consist of two DI-804V VPN Routers with a simple setup. The two remote offices in this example will be known as Office A and Office B. Both VPN Routers must already be set up and able to access each other. This is only an example, your setup will vary using the WAN IP address provided by your ISP.
Please note the differences in the IP addresses for each office.
We will begin by configuring the DI-804V at Office A. Start by going into VPN Settings under the Basic Setup menu.
Step 1. In the Connection Name field, type in OfficeA. Click ADD.
Step 2. A properties screen will appear for the new connection you have made. Fill in the appropriate information for Office A:
Connection Name: OfficeA
Local IPSEC Identifier: Local
Remote IPSEC Identifier: Remote
Remote IP Network: 192.168.1.0
Remote IP Netmask: 255.255.255.0
Remote Gateway IP: 192.170.0.2
Network Interface: WAN ETHERNET
Secure Association: IKE
Perfect Forward Secure: Enabled
PreShared Key: 123456
Key Life: 28800
IKE Life Time: 3600
Step 3 Click SAVE. There should now be a VPN policy created for Office A. Now you will want to Save & Restart the DI-804V.
Note: 123456 is an example of a preshared key, please fill in any secret preshared key you desire. Keep in mind that both sites require the same preshared key.
Office A setup is now complete, we will now configure Office B with the other DI-804V, Follow the same steps previously with Ofice A to create a VPN policy.
Step 1 Please change the appropriate information.
Connection Name: OfficeB
Remote IP Network: 192.168.0.0
Remote Gateway IP: 192.170.0.1
Key Life: 28800
IKE Life Time: 3600
Step 2 Click SAVE. There should now be a VPN policy created for Office B. Now you will want to Save & Restart the DI-804V.
After the VPN policies have been created for the two Offices, the two remote locations should authenticate and connect. To view the status of the VPN connection, go to the Device Status menu. On the bottom-left side of the menu, click on the VPN Status icon.
A VPN Status pop-up screen will appear showing VPN connection status. If a VPN tunnel is active, the State should indicate Q-Estab.
Go to a DOS prompt and ping the internal IP address of the remote network.
How do I upgrade the firmware on my DI-804V?
To upgrade the firmware on a DI-804V follow the steps below:
Step 1: Download firmware from our support site. Save and unzip it to your desktop.
Download Firmware here.
Step 2: Access the configuration page by entering 192.168.0.1 in your web browser.
Step 3: Click on the System Tools tab and then click Upgrade Firmware on the left side.
Step 4: Click the Browse button and locate the firmware file that you have downloaded and unzipped. Highlight this file, click Open, and then click Start.
Note: When upgrading the firmware, do not try to access the Internet and do not turn the power off. Doing so may cause the firmware upgrade process to abort, which will damage router.
Opening ports
To forward a specific application port please follow the steps below:
Step 1: Open your web browser and enter the IP address of your D-Link router (192.168.0.1).
Step 2: Click on the Advanced Settings tab and then select Virtual Server from the left side.
Step 3: Enter the last three digits of your IP address on the field provided and then enter the range of ports that would like to allow in. If you would only like one port to be opened, then enter the same number in each box.
Step 4: Click Submit and then Save and Restart when prompted.
9815813107 tell me name and adrress
You can find the details of the operator and the state they belong to .the operators wont reveal the address and name of any mobile numbers only higher officials can only get those information.
In order to trace the operator name and state you can try this link
http://www.indiatrace.com/trace-mobile-number-location/trace-mobile-number.php
I hope this will help you if it does do rate the answer
Thank you
regards
lalith
I have a D-link DP-300U device that I can not access
Ethernet/USB Print Server it is for even windows 98 (OMG )
page 7 is setup.
NO OS stated by you, at all. why:?
page 3 is OS compat.
after reset the default address is
192.168.0.10
5volt power pack is NOT OPTIONAL.
1998
what did you read the free manual yet.
the last page shows printer compatibility list, does your match?
where would you find a printer that old working now.
crickets...???
my guess is 2003 year made. XP first release is that.
one manual for it stamped 2003 so is 17 years old
relic fodder for sure, recycle it is best.
first hit
https://eu.dlink.com/-/media/consumer_products/dp/dp-300u/datasheet/dp_300u_datasheet_en.pdf
RTM ! no 17 year old printer works today, not really.
How to change password D-Link router DIR-655
the manual is free , at dlink dot com
you push the reset button for long time per manual 15sec (iirc)
the release it and now all defaults are set.
per the manual, google dir-655 manual.
easy as pie if you just read the manual.
How can i reset a router
There's a reset button on the back of the router, it's a small button that you can press using a paper clip. Press it for 15 seconds to reset it.
Reset 1:
Press the reset button for 15 seconds at the back of the router while the router is on.
Reset 2:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and release the reset button. Then plug the power cord back in.
Reset 3:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and plug the power cord back in while the reset button is plugged in and count another 15 seconds release the reset button.
Hope this helps.
D-link Router Tech Support Phone Number 1^877SCAMMER 69}}.support
Warning to FixYa readers -DO NOT CALL THE FAKE TECH SUPPORT NUMBERS POSTED ALL OVER THIS SITE. These phony support numbers or web links send you to criminal call centers where they will install malware, steal ID and/or extort money from you . Please only ever use the support contacts from the official company website {edited by volunteer Expert}
Help finding out my lost Network Key for an SMC Network router
go to dos prompt in a windows pc and type in ipconfig and press the enter key to find the default gateway address
it might be 10.0.0.1 or 192.168.0.1 these are the most common. Type the ip address into internet browser to log into the gateway router. There will be an admin user name and admin password. It might be the default or it might be written hopefully on the router case/
try
Username:
cusadmin
Password:
password
IP Address:
192.168.0.1
http://www.cleancss.com/router-default/SMC/SMC8014WG
if you get into it look up wi fi security to find out the wep key or wpa key
How to Contact D-link Support Australia?
At D-link, we understand the necessity of 24/7 need for an internet connection to connect you with the outside world along with providing you with optimum results as well. So, if you are facing any technical issues in your router and unable to solve it by yourself then with the tech support you can ask our experts. We will provide you Toll-Free Dlink Support Number Australia +1 888 597 3962 and online live chat so that you can reach us any moment according to your convenience.
The well-experienced and highly motivated technical teams with their years of experience at
D'link Tech Support will patiently listen to your issue and provide you with an efficient solution. You can contact our specialists at the provided number and our customer care unit will give you the necessary assistance to resolve your issue. Our customer care number is always there to take care of all your Internet-related issues and will provide you with the best available solution to permanently resolve the issue.
We provide a friendly environment and take care of each complaint and feedback to provide better services to our clients. The Toll-free Dlink Helpline Number Australia +1 888 597 3962 and help centers are available 24/7 to assist our customers and free you from your distress of the web connection of the modem and the router. At Dlink, each customer is like a member of our big family and we love to get feedback from them. So, whatever be the need we are there to serve you the best we can.
For any kind of technical help during the process contact, Router Technical Support team to get an instant solution. They are available 24/7. Call Now ?+1 888 597 3962 for any Support.
More Info -
https://www.quickhelps.co/phone-number/d-link/
