20 Most Recent
D-Link DI-808HV Router (280006OB) Questions & Answers
My dlink is restricting port 3389
YOU SHOULD FIRST HARD RESET THE MODEM USING A PAPER CLIP WHILE ITS POWERED ON AND RE CONFIGURE ALLOWING THE REMOTE ACCESS PORT TO WORK
D-Link DI-808HV Router Problem
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
The WAN light on my DI808HV is flashing quickly.
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can ssets-up form scratch.
I have three computers networked
Sometimes the router can freeze.
You can try to restart again the router by unplug power supply and then pluggin it again.
If this is not successful you may try to restore it by the little plug called restore in the back of the router (you can reach it only with a pencil or something similar because is very little). You should plug it for only some seconds otherwise the router will go back to factory settings.
Let us know if you solved your problem
Sir in my router only WAN port led blinking no lan
you may need to go into bios on the mother board and make sure that the lan is enabled. if it is then in the web browser settings the connnect lan wan might not be enabled go to exploye open it go to tools then to internet options then the security tab highlite internet the click on costum level then scrool to bottom and click on or check mark automatic logon with current user name and password and do same in each tab. the go to advance tab scroll down and uncheck last three and then you check mark ssl 2.0 ssl 3.0 and tsl 1.0 scrool backup to http and check mark both ove them there as well if you have further problems u may email me a
[email protected]
How to obtain new WAN ip-address
For the router it should suffice just to cycle its power.
However, the behavior of the ISP's DHCP server may also be part of your problem. Most likely, it also will try to assign the same address as before, if still available.
So what you can try is to switch off your router and modem for a few hours (e.g. over night) and see if you get a different address.
Of course, this won't work if you have a statically assigned IP address, as this is often the case with cable modems. In this case your only chance is to contact the provider and ask them to change your IP address. You should of course be able to offer a very good explanation then...
I am running vista and using the dlink di-808hv
Peer to peer tunneling protocal is what pptp is if its connecting a limited connectivity that means some of the ports are stull being blocked thus needing for you to use your machine in a demilierized zone so this will open all avilable ports to your VPN software. Also keep in mind not all ISP's will support PPTP so you may have to use a softvpn software. Thanks i hope this helps Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Se me olvido la Clave del router
Si te olvidaste la clave del router, proba usando la original de fabrica del router:
D-Link
usa esta direccion de acceso
http://192.168.0.1
- user=admin
password= (sin password, en blanco, solo pulsa enter)
(generalmente son (admin, password) y mira que pasa (si es que no la cambiaste)
Al resetear el router volvera a su configuracion inicial y perderas la informacion que tenia configurada. Antes de resetear podes tirar un ip config saber tus ip adresses.
Ahoras si te olvidaste la clave de acceso a tu network, podes obtenerla con cualquier aplicacion de password recovery.
Hi. i cant connecct my VPn
- Make sure you have an updated firmware on your router and after wards kindly visit this site for further instructions:
http://support.dlink.com/faq/view.asp?prod_id=1384&question=DI-804HV%20/%20DI-804V%20/%20DI-808HV
How to get two DI-808HV routers to talk
please call dlink tech support at 877-453-5465. just an advise on how to handle the call when you reach dlink tech support (agent); do not agree to call back after you troubleshoot with them (they'll be giving you a case id reference# and be advising you to check your pc or call "who" and call them back to continue the troubleshooting). insist to the agent that he need to resolve the problem asap (by the way, agents are not allowed to drop the call or they'll be dead-history!). and if the agent still insisted you to call back, ask for a "senior level technician" to finish the job (escalate the problem).
fyi: dlink tech support handling time to resolve a call is 15 to 18 minutes only. if you reach that 15-18 minutes (max) time the agent will think of a way for you to call back (advising you to check with your pc manufacturer, check with your ISP, call microsoft to update your software, etc... non-sense!) they need to do this in order to reach their handling time (agents need to reach 21 to 25 billable calls, and billable calls are "solution provided", "resolved", and "dropped call"). ---- believe me, i was one of them and repented.
I have not been able
Try resetting the router . Press the reset button for 10 seconds and after 10 seconds unplug the power cable but continue pressing the reset button for another 30 seconds after 30 seconds plug in back the power cable and continue pressing the reset button for 10 seconds and release it after 10 seconds.
try to open an Internet browser and type in 192.168.0.1 on the address bar. It should give you the DLink page. Once you have that configure your connection.
9815813107 tell me name and adrress
You can find the details of the operator and the state they belong to .the operators wont reveal the address and name of any mobile numbers only higher officials can only get those information.
In order to trace the operator name and state you can try this link
http://www.indiatrace.com/trace-mobile-number-location/trace-mobile-number.php
I hope this will help you if it does do rate the answer
Thank you
regards
lalith
