20 Most Recent
D-Link AirPremier DWL-3200AP 802.11g/b (790069273544) Wireless Access Point Questions & Answers
How to upgrade framewire dlink
Download the firmware, over a "wired" connection from your computer to your D-Link. Login to the router's built-in web-interface, and lick the "update firmware" link. Point to the downloaded firmware, and do the update.
5/7/2015 5:58:02 AM •
D-Link...
Answered
on May 07, 2015
Latency time is more
Turn TWELVE of the devices off, and measure it again.
Turn one of the twelve on, and measure it again.
Turn on the next of the twelve, and measure it again.
Repeat until you find the one that increases the latency.
5/7/2015 5:12:08 AM •
D-Link...
Answered
on May 07, 2015
Cannot Access My DWL-3200AP
If you can browse internet via same device
Start/ Run/ CMD/ type "ipconfig" (w/o ")
Use default gateway IP address as your AP ip address..
Enable java and use IE (some devices prefere IE)
e remember to score this tip.
12/21/2013 3:42:28 AM •
D-Link...
Answered
on Dec 21, 2013
One dlink 8port switch &
Connect a LAN cable from the D-Link to your laptop/computer'sLAN port, open the browser on your laptop/computer and enter the D-Link'sconfiguration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter)
You can now configure the wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
4/9/2011 1:56:07 AM •
D-Link...
Answered
on Apr 09, 2011
How to configure the ap
First, make sure you disable the proxy if you`re using one, then open up your web browser and type in this address: 192.168.0.50. A login dialog will show up. The username:admin , left the password empty. Log in, and from there you can configure your AP.
Good luck
4/1/2011 4:33:03 AM •
D-Link...
Answered
on Apr 01, 2011
How to do password lock
Check out the manual at
http://www.retrevo.com/support/D-link-DWL-3200AP-manual/id/420ci562/t/2/Presumably you are asking about encryption and how to stop your neighbours and anyone else nearby picking up the signal from using your connection.
Most routers have an option to enter the mac address (which all wifi components have one of) to create a list of trusted devices the router will accept connections from, barring any that are not in the list.
3/25/2011 12:33:44 PM •
D-Link...
Answered
on Mar 25, 2011
I'm using d-link dwl-3200 ap
Transmitted Error Count 4734440
Ack Rcv failure Count 15269951
- As per the above there are error on Transmitting the packet
and also for receiving the acknowledge packet.
- Please check whether any
disturbance in the link
- Each PPP packet has a checksum attached to ensure
that the data being received is the data being sent. If the FCS of an incoming
packet is incorrect, the packet is dropped and the HDLC FCS count is increased.
- Another reason for seeing too many FCS errors may be that the remote end has
stopped talking PPP.
2/28/2011 10:35:41 AM •
D-Link...
Answered
on Feb 28, 2011
With Direct cable ,internet connection
This is most likely due to the still having the Media Access Control (MAC) address of the device that was previously connected the modem in NVRAM.
In order to clear this old MAC address, the easiest thing to do is to unplug the power cable from the modem for 15 to 20 minutes. This allows the NVRAM in the modem to clear and makes it able to accept the new MAC address of the router.
After the modem has been unplugged from the power for 15 to 20 minutes, plug the Ethernet cable of the router into the modem and plug the power cord back in to the modem. After the modem syncs back up to the network, it should add the MAC address of the WRT54GL router to its NVRAM and assign it an IP address. This should allow the router to connect your systems to the Internet.
Please be sure to rate my answer as a 3 or 4 thumbs up if you found it helpful. The 1 and 2 thumbs-up are like saying "didn't really address the problem" and "wasn't the best solution"
2/21/2011 2:37:03 AM •
D-Link...
Answered
on Feb 21, 2011
D-link dwl-3200ap not given the
Try to reset the network adapter. This can be done by finding the network and right-clicking it and selecting Diagnose.... It should give a few options, select Reset network Adapter.... If that doesn't work, consult D-Link Tech Support....
1/8/2011 9:26:01 PM •
D-Link...
Answered
on Jan 08, 2011
I have 3 Dlink access points DWL3200AP
You can use adapter of DWL-2700Ap and use POE to power your access point. It will work fine. If that is not available, you can mail us. we can arrange the adapter in India. You can contact us at
[email protected]. Good Luck Anirban
8/14/2010 3:02:27 PM •
D-Link...
Answered
on Aug 14, 2010
