20 Most Recent
D-Link AirPremier DWL-8200AP 802.11a, 802.11g/b (DWL8200AP) Wireless Access Point Questions & Answers
Can't connect to configure password through web address 192.168.0.50
When you reset the AP, how long did you press the reset button? To reset the AP to factory defaults, the reset button should be pressed and held for at least 15 seconds. Also, once reset, the AP should have the following settings:
IP address: 192.168.0.50
Subnet Mask: 255.255.255.0
Default admin username: admin
Default admin password: <blank>
When connecting your PC, either set an IP address within the same subnet (192.168.0.51 255.255.255.0) or choose "Obtain address automatically".
I hope this helps.
Dave Grannas
2/16/2009 1:17:43 PM •
D-Link...
Answered
on Feb 16, 2009
9815813107 tell me name and adrress
You can find the details of the operator and the state they belong to .the operators wont reveal the address and name of any mobile numbers only higher officials can only get those information.
In order to trace the operator name and state you can try this link
http://www.indiatrace.com/trace-mobile-number-location/trace-mobile-number.php
I hope this will help you if it does do rate the answer
Thank you
regards
lalith
I have a D-link DP-300U device that I can not access
Ethernet/USB Print Server it is for even windows 98 (OMG )
page 7 is setup.
NO OS stated by you, at all. why:?
page 3 is OS compat.
after reset the default address is
192.168.0.10
5volt power pack is NOT OPTIONAL.
1998
what did you read the free manual yet.
the last page shows printer compatibility list, does your match?
where would you find a printer that old working now.
crickets...???
my guess is 2003 year made. XP first release is that.
one manual for it stamped 2003 so is 17 years old
relic fodder for sure, recycle it is best.
first hit
https://eu.dlink.com/-/media/consumer_products/dp/dp-300u/datasheet/dp_300u_datasheet_en.pdf
RTM ! no 17 year old printer works today, not really.
How to change password D-Link router DIR-655
the manual is free , at dlink dot com
you push the reset button for long time per manual 15sec (iirc)
the release it and now all defaults are set.
per the manual, google dir-655 manual.
easy as pie if you just read the manual.
How can i reset a router
There's a reset button on the back of the router, it's a small button that you can press using a paper clip. Press it for 15 seconds to reset it.
Reset 1:
Press the reset button for 15 seconds at the back of the router while the router is on.
Reset 2:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and release the reset button. Then plug the power cord back in.
Reset 3:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and plug the power cord back in while the reset button is plugged in and count another 15 seconds release the reset button.
Hope this helps.
D-link Router Tech Support Phone Number 1^877SCAMMER 69}}.support
Warning to FixYa readers -DO NOT CALL THE FAKE TECH SUPPORT NUMBERS POSTED ALL OVER THIS SITE. These phony support numbers or web links send you to criminal call centers where they will install malware, steal ID and/or extort money from you . Please only ever use the support contacts from the official company website {edited by volunteer Expert}
Help finding out my lost Network Key for an SMC Network router
go to dos prompt in a windows pc and type in ipconfig and press the enter key to find the default gateway address
it might be 10.0.0.1 or 192.168.0.1 these are the most common. Type the ip address into internet browser to log into the gateway router. There will be an admin user name and admin password. It might be the default or it might be written hopefully on the router case/
try
Username:
cusadmin
Password:
password
IP Address:
192.168.0.1
http://www.cleancss.com/router-default/SMC/SMC8014WG
if you get into it look up wi fi security to find out the wep key or wpa key
