20 Most Recent
D-Link (DWL-2200AP) 802.11g/b Wireless Access Point Questions & Answers
Pls i assigned an IP to my DWL 2100AP wireless AP
Under Windows 7, press the "Start" button.
Type 'cmd' into the search-box, and press ENTER.
Type 'ipconfig /all', and press ENTER.
Look for the IP-address for the "gateway" (or "DHCP-server").
Type that IP-address into your web-browser.
5/7/2015 5:52:17 AM •
D-Link...
Answered
on May 07, 2015
Forgot admin password
If the default password on the D-Link has been changed then - To reset the D-Link back to the default settings - Press and hold the RESET button at the back of the router with the power ON until the LEDs flash at the time the release the RESET button. (firmware version was 3.00, and upgraded to 3.05) Connect a LAN cable from the D-Link to your laptop/computer's LAN port, open the browser on your laptop/computer and enter the D-Link's configuration URL.. http://192.168.0.1 The default login = admin The default PW = blank (just press Enter) You can now change the default admin password. You can now configure the wireless settings. (WPA or WPA2 encryption) Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
11/21/2012 8:01:19 AM •
D-Link...
Answered
on Nov 21, 2012
No password
You can reset to factory defaults by holding in the reset button for about 10 seconds while powering up.Then you can log in with 'admin' and password 'admin'
2/21/2011 3:35:31 AM •
D-Link...
Answered
on Feb 21, 2011
How do I reset the password and username on my
To reset the D=Link back to the default settings -
Press
the RESET button at the back of the router and power it up. Hold the
RESET button for 5 secs. until the LEDs flash at the same time.
Connect a LAN cable from the D-Link to your computer's LAN port, open a browser and enter the D-Link;s configuration URL.
http://192.168.0.1
You can now go to the wireless settings.
2/11/2011 2:21:33 AM •
D-Link...
Answered
on Feb 11, 2011
Can not open wizard
You can reset your router.
To reset your router, use the following steps (from
http://technicallyeasy.net/2008/02/how-to-reset-d-link-di-524-wireless/):
- Press the reset button [the tiny button on the back of your router, marked Reset] for 10 seconds. You can use a small object, such as a paper clip to hold down the button.
Do not power off the unit while the router is being reset.
The unit should now reboot, and once the WLAN light stops blinking the router should be reset.
- Open up your Web browser and enter 192.168.0.1 in the address bar.
- For the login, enter admin as the ID and leave the password blank.
The router has now been reset. Follow the steps in
Securing D-Link DI-524 Wireless Router to secure your router.
admin username:
admin
Default admin username:
admin
Default admin
password:
<blank>
8/16/2009 9:58:40 PM •
D-Link...
Answered
on Aug 16, 2009
9815813107 tell me name and adrress
You can find the details of the operator and the state they belong to .the operators wont reveal the address and name of any mobile numbers only higher officials can only get those information.
In order to trace the operator name and state you can try this link
http://www.indiatrace.com/trace-mobile-number-location/trace-mobile-number.php
I hope this will help you if it does do rate the answer
Thank you
regards
lalith
I have a D-link DP-300U device that I can not access
Ethernet/USB Print Server it is for even windows 98 (OMG )
page 7 is setup.
NO OS stated by you, at all. why:?
page 3 is OS compat.
after reset the default address is
192.168.0.10
5volt power pack is NOT OPTIONAL.
1998
what did you read the free manual yet.
the last page shows printer compatibility list, does your match?
where would you find a printer that old working now.
crickets...???
my guess is 2003 year made. XP first release is that.
one manual for it stamped 2003 so is 17 years old
relic fodder for sure, recycle it is best.
first hit
https://eu.dlink.com/-/media/consumer_products/dp/dp-300u/datasheet/dp_300u_datasheet_en.pdf
RTM ! no 17 year old printer works today, not really.
How to change password D-Link router DIR-655
the manual is free , at dlink dot com
you push the reset button for long time per manual 15sec (iirc)
the release it and now all defaults are set.
per the manual, google dir-655 manual.
easy as pie if you just read the manual.
How can i reset a router
There's a reset button on the back of the router, it's a small button that you can press using a paper clip. Press it for 15 seconds to reset it.
Reset 1:
Press the reset button for 15 seconds at the back of the router while the router is on.
Reset 2:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and release the reset button. Then plug the power cord back in.
Reset 3:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and plug the power cord back in while the reset button is plugged in and count another 15 seconds release the reset button.
Hope this helps.
