20 Most Recent
BEL 880 Radar Detector Questions & Answers
Lost sound entirely
THis happens has the resistor board has lost current to the speaker. This is more common on the cobra dectors but it can happen to all of them. If i were you i would send it in and get it serviced by a pro tech but if you know what your doing open it up and remove the resistor pack and replace it. If that doesnt solve the problem replace the speaker. You can find a speaker at your local radio shack
Code ?lo1 cal comes up and wont go off
This means that the primary local oscillator couldn't be calibrated during the RD's self-calibration procedure. You could get your RD repaird by Bel/Escort, but with these older models, your best bet would be to take advantage of Bel/Escort's trade-in offer to get a current model which provides significantly better performance -- particularly with regards to Ka band radar.
Bel 880 sound
Call bel, the number is on the label on the bottom, I am having the same problem with mine, he was very helpful and said it was probably the speaker which they sell for $8. If your handy with a soldering iron its simple repair. Or they offer a trade up service, giving you like $80 towards a new unit.
No sound from the bel 880 radar detector
I have the same detector and my sound just went out, I called the number on the label on the bottom. They where very friendly and told me that it was more than likely the little speaker, they sell them for $8, if you are handy with a soldering iron its a simple task.
BEL 880 USER MANUAL
There is a phone number to bell on the bottom and they are very helpful.
Good Luck! Its a great detector.
My E550 Beltronics detector has developed a problem
you can try out some guide from reliable-store
they also provide live chat feature for instant help and it's very useful
using that I fixed my own excavator 5-6 times without any other help
plus free so whats harm in not getting
Using wrong power cord
Sounds like a dirty receptacle. If you're a smoker, I guarantee that's the problem. Take the cigarette lighter fuse out of your vehicle and clean the receptacle with sandpaper wrapped around a small stick. Good luck!
Beltronics rx65 service required can I fix this
This detector - along with other high-end types that require a microprocessor to analyze signals - performs a self-test when powering up. This is done for the same reasons a Power On Self Test is done on your computer. There's a lot going on inside and if just one area is malfunctioning data may not be processed correctly and in the case of the detector - resulting in aggravating false alarms or worse - not indicating an alert when needed.You should arrange for the detector's return to Beltronics for thorough checking / realignment. Contact Beltronics via this
link.I hope this helps!
