20 Most Recent
Viking VDB325SS Dishwasher Questions & Answers
My viking vdb325ss dishwasher runs for a few minutes and then stops with control pad lights blinking. The "normal cycle" and "pots and pans" lights blink together. I have reset and restarted the dis
Hello Peter!
Your owners manual or a call to Viking should help you decode the blinking panel lights. They are not random and are a desperate cry for help from the machine.
It has been my experience (YMMV) that a common dishwasher problem in older machines is accumulated grunge (the technical term) in the water level sensor. In many cases the sensor lives in a plastic container on the side of the DW and although the designers try hard to avoid contamination, the container eventually loads up and intermittently jams the float.
Before I pulled the unit however, I'd check the bottom of the wash cabinet for contaminants. There may be an screen (under a cover plate) that has clogged.
Your situation sounds a bit different, since my Samsung did not pump out water, it just stopped and flashed a code, but who knows? Go for the low-hanging, common issues first.
All the best.
Viking VDW302SS--trying to pump out water that isn't there
If your machine is trying to pump out water that is not there, check the float level sensor. That is the detector that checks for water level during filling. If the pipe/mechanism is blocked, in the full position, the sensor will indicate that there is still water to be pumped out ... that is assuming the water has been pumped out otherwise look for a blockage in the outlet pipe.
3/12/2023 8:07:32 PM •
Viking...
Answered
on Mar 12, 2023
