20 Most Recent Simrad TP32 Autopilot System Questions & Answers
Can I install a TP23 at 20 instead of the recommended 18
Hi Sean. I'll need a little more info to be able to attempt to help you out. 20.. 18... Volts? Delay? -Steve
6/11/2015 11:47:45 AM • Simrad TP32... • Answered on Jun 11, 2015
2answers
I need to reset Simrad AI50 ais to a new MMSI.. Thank you
This is the official line Can I change the MMSI number entered into a VHF radio or AIS unit? Once entered and confirmed, the MMSI number can only be changed by a certified technical dealer. If you need your number reset or changed, it is recommended that you contact the organization or agency which originally registered your MMSI. For more information about MMSI numbers, go to the United States Coast Guard website at this link. And https://www.justanswer.com/boat/au99m-received-emailed-info-from-simrad-reset.html This doesn't sound hopeful! https://mt.panbo.com/2015/07/simrad-ai50-mmsi-reset.html Full story https://www.google.com/search?q=reset+Simrad+AI50+ais+to+a+new+MMSI ..
11/22/2023 9:29:51 AM • Simrad Boating • Answered on Nov 22, 2023
Simrad NSS EVO 3. The Bus is off. Need to turn on?
Question edited for clarity. Question moved from Computers and Internet. Check out the first two links https://www.google.com/search?q=NSS+EVO+3+Bus ..
3/4/2022 11:41:20 PM • Simrad Boating • Answered on Mar 04, 2022
2answers
Need to replace my control head for my SimRad HS 50 auto pilot system. Where can I find one?
CHECK WITH A BOAT DEALER
11/30/2020 12:11:37 AM • Simrad Boating • Answered on Nov 30, 2020
I have a simrad cr44 chart plotter and would like to know how to set the track up mode. Thank you Steve
If you plan to sell the simrad CR44. Im willing to buy it. Thanks
1/29/2020 9:48:16 PM • Simrad Boating • Answered on Jan 29, 2020
My simrad ap50 autopilot goes hard over at random times when running on the jog lever
I would start by looking for a wiring problem - loose, corroded, frayed, shorting.......
9/5/2019 11:55:00 AM • Simrad Boating • Answered on Sep 05, 2019
I have a Simrad GO5 XSE. I was wondering if there is any way to check the engine hours?
You wont be able to see engine hours without using a engine specific interface cable that will let these 2 pieces of equipment to talk to one another.You can also use a Nema 2000 network to interface these together to get engine hours but the go5 alone wont be able to get this information for you.
6/30/2019 12:43:39 AM • Simrad Boating • Answered on Jun 30, 2019
I went out to the continental shelf fishing in depth of 250 meters . My echo sounder is a simrad nss evo 16. I had problems while drifting the sounder would freeze how can I fix this
I did a search and found this as I don't own one not sure if this forum will help or not but thought I'd pass it on anyway. Best to you. https://www.thehulltruth.com/marine-electronics-forum/645739-problems-simrad-nss-evo2-chirp-structure-scanner.html
1/11/2018 11:05:32 PM • Simrad Boating • Answered on Jan 11, 2018
Simrad nx40 master reset
http://test.new.simrad-yachting.com/Root/kimberly/NX40-45_IM_EN_MN000790_C_w.pdf Setup --> System --> Factory Reset If you download the manual, you can search it with CTRL-F. Search for Reset brought me to the instruction above.
8/29/2017 7:38:28 PM • Simrad Boating • Answered on Aug 29, 2017
0answers
0answers
I am looking for a Simrad AT 40 for my Simrad NX 10 In Holland are not anymore availble. I need for my Simrad gps GS10 [email protected]
Hi Your best bet here would be to contact Simrad in England. The link is below and I hope they are able to help you out. -Steve http://www.simrad-yachting.com/en-GB/Contact-Us-UK/
4/2/2015 5:25:25 AM • Simrad Boating • Answered on Apr 02, 2015
My simrad ca44 keeps turning itself on and off
This is almost always a power supply issue. Check and clean your positive and negative connections. Although the link below is for car batteries, the principles are the same. If that gives you no joy, check the plug and socket of your unit. It doesn't take much corrosion to render an electronic device inoperable. Hope this helps. -Steve How to Clean Car Battery Terminals
3/3/2015 2:10:27 PM • Simrad Boating • Answered on Mar 03, 2015
0answers
Chirp settings
Be the first to answer 11/4/2013 6:17:04 AM • Simrad Boating • Posted on Nov 04, 2013Be the first to answer
Simrad TP32 Autopilot System Logo
1 questions posted
Top Simrad Boating Experts
vince
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Are you a Simrad Boating Expert? Answer questions, earn points and help others
View Most Popular
Simrad Boating
  • Simrad Boating
Most Popular Question
install tp23 20 instead recommended 18
  • Boating
