20 Most Recent Edimax BR-6104K Router (br6104k) Questions & Answers
2answers
How to hack crossfire account
only with linux
and aircrack program
3/17/2014 6:51:26 PM • Edimax BR-6104K... • Answered on Mar 17, 2014
Edimax wireless-g broadband router
please confirm if the router is a 6104K, or a KP or Wg or another model as the K and KP are not wireless, a "W" will denote wireless capability...
Not all manuals are available for download from the Edimax website but heres a start...
Connect the router to your PC with a cable... leave the modem disconnected to start with
open internet explorer and type in enter the default IP address 192.168.2.1 (broadband router’s IP address) into your PC’s web browser and press <enter>
This should bring up a user/password dialog box. By default the user name is "admin" and the password is "1234".
Confirm you are getting this far and we'll go the next steps
9/7/2013 7:53:42 AM • Edimax BR-6104K... • Answered on Sep 07, 2013
Unable to login to the router's admin
Hi there!
Try resetting your router. There's a reset button at the back of the router. Press it for 10 seconds to reset it to factory settings. You should be able to connect to your router without being asked for a wep key or password.
Happy surfing!!!
^_^
8/1/2013 8:11:10 AM • Edimax BR-6104K... • Answered on Aug 01, 2013
What is the default username and pass word for
password is :1234 username is :admin
6/9/2013 5:06:26 AM • Edimax BR-6104K... • Answered on Jun 09, 2013
Edimax ar-7284WnA router - i type in the password but it just stays on the log in page
Are you the computer's Administrator? Reboot the wireless device and the computer. Repeat.
2/1/2013 5:45:25 PM • Edimax BR-6104K... • Answered on Feb 01, 2013
2answers
Edimax br-6104k
do you have apppoe connection or dhcp? release your ip address (ipconfig/release) set your modem to bridge mode then connect modem and router. try to connect.
marlon
3/24/2012 8:55:06 AM • Edimax BR-6104K... • Answered on Mar 24, 2012
2answers
My internet become very lag when playing online game
First, try to reset and reconfigure the router. If that doesn't resolve the issue, you must update the firmware of the router. After updating the firmware, it is recommended to do a hard reset. Hold the reset button at the back of the router for 20 seconds, then unplug the power cable for 20 seconds and plug it back in. That should resolve the laggy issue.
3/24/2012 8:54:01 AM • Edimax BR-6104K... • Answered on Mar 24, 2012
How to configure edimax router BR-6104K
How to configure edimax router BR-6104K Problem with the Edimax BR-6104K Router
6/21/2011 1:50:30 PM • Edimax BR-6104K... • Answered on Jun 21, 2011
2answers
What is MTU? wut does
Hello - MTU stands for Maximum Transmission Unit which is a measure of the size of a data "chunk" that can be sent over a network at a time. For example, if you are connected to the Internet using Ethernet the standard MTU is 1500 bytes while being connected over a WiFi connection would mean your using an MTU of 2272 bytes while an old fashioned modem would send 576 bytes at a time.
The MTU usually refers to the TCP/IP protocol which was developed for and is the networking standard for the Internet. MTU has standards for different networking devices, Ethernet, Modems, etc. but they can be modified for the purpose for special uses to achieve greater efficiency.
To read more about MTU there is a more complete description of it at the Wikipedia entry HERE.
Happy Networking
Mikeywaf
3/19/2011 5:32:59 AM • Edimax BR-6104K... • Answered on Mar 19, 2011
How to Configure this laptop?? I buy this router
Here is where you can download the manual and quick installation guide for your router. Click on the link.
I hope this will be helpful to you.
Thank you for choosing fixya
3/16/2011 9:24:53 AM • Edimax BR-6104K... • Answered on Mar 16, 2011
My edimax BR-6104 Router cannot read internet
Are you sure you are using the latest firmware?
if you are not you will lose connection..
so please update the firmware.just search the net for the latest firmware
2/12/2011 3:35:35 PM • Edimax BR-6104K... • Answered on Feb 12, 2011
Need driver for edimax br-6104k
THERE ARE NO DRIVERS FOR THE ROUTERS.WAHTS THE PROBLEM AAND WHAT DO YOU WANT TO DO.
1/4/2011 10:58:18 AM • Edimax BR-6104K... • Answered on Jan 04, 2011
I need the driver for
http://www.nodevice.com/driver/BR-6104K/get47431.html
hope it helps.
If this helps you resolve your problem, please
consider giving me a good rating and a quick
thanks or good job.It will help me as well.
Thank you.
10/26/2010 3:00:10 PM • Edimax BR-6104K... • Answered on Oct 26, 2010
2answers
Wireless security-enabled network
That should be in your router under "wireless", and then "security" Make sure all your devices share and support the security you haver picked. In other words if you pick WPA2, you should prolly pick WPA2/mixed with TKIP/AES, ect. Dont pick WEP unless you have an older card. Its too easy to crack.
12/3/2009 7:11:02 PM • Edimax BR-6104K... • Answered on Dec 03, 2009
3answers
Edimax Router BR-6204WG - setting as
I believe I can help.
As I understand you use your Siemens to get to Internet and you like to use another Edimax 6204 WL Router on another floor.
You don't have to change much !
First check if DHCP on your Siemens Router is ENABLED (it should be) !
- RESET your EDIMAX Router (to be sure everything is set by default)
and disconnect any LAN cables from it.
- If you are using Laptop (or desktop with WL adapter), connect it to your EDIMAX by LAN cable.
- Set (if it is not) LAN adapter IP and DNS of your Laptop/Desktop
to 'Obtain an IP address automatically'
If it was seto to some STATIC IP, after this you may need to 'REPAIR' your LAN connection
to get a new IP from your Edimax router
- Open your browser and type http://192.168.2.1
(admin + pass: 1234)
- Go to Wan port and check it. It should be set to Dynamic IP.
- Go to LAN settings and type IP address of the Edimax Router in the same Class
as Siemens Router is. (e.g. if Siemes router is 192.168.1.1 then Edimax should be 192.168.1.2)
- Change the DHCP range too, but be carefull this range should be different from DHCP range on your
Siemens router. (e.g. if Siemens router range is 192.168.1.100 to 192.168.1.200, then you should
set Edimax DHCP range from 192.168.1.201 to 192.168.1.250)
- Now, connect the LAN cable from one of Siemens LAN port to WAN port of your Edimax.
That's it!
Now you may change SSID, Security, Time etc. on your Edimax router, and also try to connect via your Laptop's WL adapter. (also make sure it has no static IP address)
Hope this helped.
12/3/2009 2:20:40 AM • Edimax BR-6104K... • Answered on Dec 03, 2009
Lost of connection to internet
Are you using the latest firmware version?
11/29/2009 5:10:30 AM • Edimax BR-6104K... • Answered on Nov 29, 2009
How do I set security network on my Edimax (i.e.
I've been trying to figure out this problem and solved the darn thing just in time.
This is what I did --> http://zeebigtourist.blogspot.com/2009/11/just-addendum-to-my-previous-post.html
Thanks for all the helpful info, FixYa.
ZeeBigTourist
11/10/2009 7:10:01 AM • Edimax BR-6104K... • Answered on Nov 10, 2009
Edimax BR-6104K Router (br6104k) Logo
75 questions posted
Top Edimax Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Edimax Computers & Internet
Most Popular Question
mtu wut
  • Computers & Internet
