20 Most Recent Jmlab Cobalt SW27A Speaker Questions & Answers
Check your connections. Make sure everything is plugged in properly. If it is still making a sound, even a whisper, then the amp is probably fine. Do you have other speakers connected to the amp? If so, they should be sounding too. If not, then it's definitely an amp problem. Ebay sells tons of .... well, everything, so you should check that out...
Jmlab Audio... | Answered on Mar 05, 2014
Hello unfortunately it sounds as if the coils in both woofers are open,you have pretty much confirmed this by your direct connection however putting an ohmmeter across the terminals will tell you as well.If you have a meter the woofer should measure approx 6 ohms,if it measures 0 its bad.Another simple way to tell is with a 9 volt battery,simply connect with two wires and see if the woofer pops if not its no good.
Jmlab Audio... | Answered on Feb 25, 2011
Hi Eve, I could have a problem with your NYNE ROCK charger or battery
I suggest that your charger is working, should deliver to the connector that is plugged into the equipment, approximately 18 volts DC, is not a dangerous voltage value and if not, try another charger compatible with your computer and verify that charge the battery of your NYNE ROCK, s this does not happen, it is very likely that the battery is bad, contact a specialized technical service
I enclose the user manual
I hope he manages to solve the problem
Greetings Franco Dosil
Hola Eve, podr?a tener problema con el cargador o la bater?a de su NYNE ROCK
Le sugiero que su cargador este trabajando, deber?a entregarle en el conector que se enchufa en el equipo, aproximadamente, 18 volts de corriente continua, no es un valor de tensi?n peligrosa y si no, pruebe con otro cargador compatible con su equipo y verifique que cargue la bater?a de su NYNE ROCK, s esto no sucede, es muy factible que se encuentre mal la bater?a, dir?jase a un servicio t?cnico especializado
Le adjunto el manual de usuario
Espero que logre resolver el problema
Saludos Franco Dosil
https://www.manualslib.com/manual/1314972/Nyne-Rock.html
Audio Players &... | Answered 17 hours ago
Hello Jack, please specify brand and model of your speaker, which needs a charger
I am looking forward to your response
Hola Jack, por favor especifique marca y modelo de su altavoz, del cual necesita un cargador
Espero su respuesta
Flip Display:1. Press the Select button to enter Flip Display.2. Press the Select button to flip the screen upside down so that you may mount the unit on your vehicle's visor.Note:You may also flip the display by pressing and holding the DISPLAY button on the XACTVisor Sirius Satellite Radio Receiver or the Remote Control for 2 seconds.
Manual Here http://www.siriusretail.com/pdf/manuals/XTR3_Manual.pdf
Audio Players &... | Answered 19 hours ago
Hello Lillies, it would be good if you published the exact model of your "Samsung gigantic sound system m00" and I can not interpret which would be inconvenient that you have with your Samsung
Please tell me what I'm saying, so I can help you solve the problems and you can enjoy the equipment
I wait your answer
Hola Lillies, seria bueno que publiques el modelo exacto de tu "Samsung gigantic sound system m00" y no logro interpretar cual seria en inconveniente que tienes con tu Samsung
Por favor comentame lo que te indico, como para poder ayudarte a solucionar los problemas y puedas disfrutar de equipo
Espero tu respuesta
Audio Players &... | Answered 23 hours ago
Hello Sheridan, for what you comment, you have a problem in the CD reading stage, if you have technical knowledge, with the equipment disconnected from the power network, I suggest you remove the lid of the equipment and try to access the area where find the mechanism of the CD player, this equipment has 1 CD player so it is not complicated, once located try to clean the lens of the reader with a slightly moistened with alcohol, preferably using isoprpyl alcohol, then let it dry a few seconds, carefully connect the device, turn it on and place a CD, see if it reads it, if that is the problem solved, if not, you would have to replace the laser reader or approach a specialized technical service
I hope you can solve the problem
I have attached the service manual of your Panasonic
Hola Sheridan, por lo que comentas, tienes un problema en la etapa de lectura de CD, si tienes conocimientos tecnicos,con el equipo desconectado de la red de energia, te sugiero sacar la tapa del equipo y tratar de acceder a la zona donde se encuentra el mecanismo del reproductor de CD, este equipo tiene reproductor de 1 CD por lo cual no es complicado, una vez localizado trata de limpiar la lente del lector con un isopo levemente humedecido con alcohol, preferentemente usar alcohol isoprpilico, luego de eso deja secar unos segundos, conecta con cuidado el aparato, prendelo y coloca un CD, observa si lo lee, si es asi problema resuelto, si no, tendrias que reemplazar el lector laser o acercarte a un servicio tecnico especializado
Espero puedas solucionar el inconveniente
Te adjunto el manual de servicio de tu Panasonic
https://www.manualslib.com/manual/764829/Panasonic-Sa-Akx14lm-K.html
TPS = Tape Program Sensor
It finds silent gaps between songs while rewinding or fast-forwarding of cassette-tape in play mode.
Audio Players &... | Answered Yesterday
How to.setup.remote rc799m.to My onkyo receiver tx sr 578
Hello Raymond, to replace the fusibble you must disarm the Beolab, I have attached the link so you can download the Service Manual and follow the instructions
Keep in mind that if the fuse is blown, what caused that action?
he may replace it and burn again
If this happens, go to a specialized technical service
Hola Raymond, para reemplazar el fusibble debe desarmar el Beolab, le adjunto la link para que pueda descargar el Service Manual y siga las indicaciones
Tenga en cuenta que si se quemo el fusible, que produjo esa accion?
puede que lo reemplace y se vuelva a quemar
Si eso ocurre , concurra a un servicio tecnico especializado
https://elektrotanya.com/bang-olufsen_beolab_4000.pdf/download.html
Hello Jim, for what you say, the arm of your tray returns before you finish reading the disc?
If so, it may be that the return system of the arm is stuck or missing cleaning or lubrication, if you have the knowledge, should review the operation of said system, suggestion, remove the lower cover of the tray and aopye the tray in four high legs, which allow you to see the operation of the mechanism and see if it is working free or stuck
If not, go to a specialized technical service
Hola Jim, por lo que expresa, el brazo de su bandeja retorna antes de que termine de leer el disco?
Si es asi, puede ser que se encuentre trabado o falto de limpieza o lubricacion el sistema de retorno del brazo, si tiene los conocimientos, deberia revisar el funcionamiento de dicho sistema, sugerencia, retire la tapa inferior de la bandeja y aopye la bandeja en cuatro patas altas, que le permitan ver el funcionamiento del mecanismo y ver si esta trabajando libre o atascado
si no, concurra a un servicio tecnico especializado
https://www.manualslib.com/products/Technics-Sl-Bd20-Service-2611757.html
Just google it. We live in the 21st century, not to ask questions like this.
Audio Players &... | Answered 2 days ago
Jmlab Cobalt SW27A Speaker Logo
Popular Tags
0 questions posted
Top Jmlab Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Jmlab Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Jmlab Audio Players & Recorders
Most Popular Question
subwoofer repair
  • Audio Players & Recorders
