20 Most Recent Efficient Networks Siemens SpeedStream Powerline 2510 DSL/Cable Router (936-2510-001) Questions & Answers
Try Speedstream.com and specifically:
http://kb.efficient.com/display/1n/index.asp?c=&cpc=&cid=&cat=&catURL=&r=0.9983179
Efficient... | Answered on Jun 19, 2008
Look for a small reset button. It would typically be concealed in a small hole where it can be pressed with a paper clip. Try pressing the reset button for about 15 seconds, then release it. If this fails to reset to defaults, turn off the power...press the reset button....turn on the power while holding the reset button in...continue to hold the reset button for about 15 seconds.
Good luck...and I hope this is helpful!
Efficient... | Answered on Jan 23, 2008
Devices which can affect Powerline throughput inclued blow dryers, electric drills/saws, vacuum cleaners, and window-mounted air conditioners.
Efficient... | Answered on Feb 19, 2006
Our Powerline devices have security that will prevent anyone from seeing your Powerline network. Using the utility provided with the device, you can encrypt all data transfers over powerline to 56 bit DES. In addition, the range of the powerline signal is limited, in order to help prevent others from accessing the data stream.
The default password is SpeedStream. Note that this password is case sensitive.
No. Currently we are only offering Powerline products for the North American market, with support for standard 120 Volt AC, 60 Hz electrical outlets. Simply plugging a 120 > 220 volt adapter will not work, as the transformer will block the broadband signal, not to mention that the increased voltage that is likely to leak through a standard adapter could destroy the product.
While the homeplug 1.0 standard was optimized for homes of around 2000 square feet, our Powerline devices have been tested with excellent results in homes of up to 7,000 square feet.
Yes, in most cases this USB device will work properly through a USB hub; however, we recommend that you plug the device directly into the USB port on your computer for best performance.
We recommend that there be no more than 10 computers active on a Powerline network at one time. It is possible to have more than this, but throughput will be greatly diminished.
No; the Powerline products have a built-in surge protector. Plug the unit directly into the wall socket.
tripp-lite 40kva ups rectifier on,but invertor not on ,alarm coming auxiliary supply abnormal
Efficient... | Answered on Apr 04, 2014
How far have you got and what exactly are you having trouble with - ?
Efficient... | Answered on Oct 30, 2010
Its asking for the username because in ur router, wi-fi protected set up(WPS) is enabled. Acsess the router's set up page using its default IP, and disable the WPS option, it wont ask for username and password anumore.
Efficient... | Answered on Aug 12, 2010
Any encryption key will be specific to a network so no there is not a free universal key. If you find a non encrypted network like at Panera Bread Co. then you don't need a key.
Efficient... | Answered on Nov 18, 2009
Efficient Networks Siemens SpeedStream Powerline 2510 DSL/Cable Router (936-2510-001) Logo
12 questions posted
Top Efficient Networks Computers & Internet Experts
pongta rajkumar
pongta rajkumar
Jeffrey Groves
Jeffrey Groves
Duncan Mutch
Are you an Efficient Networks Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Efficient Networks Computers & Internet
Most Popular Question
factory defaults ss2510 powerline router
  • Computers & Internet
