20 Most Recent Efficient Networks Siemens SpeedStream Powerline 2524 Wireless DSL/Cable Router (936-2524-001) Questions & Answers
Devices which can affect Powerline throughput inclued blow dryers, electric drills/saws, vacuum cleaners, and window-mounted air conditioners.
Efficient... | Answered on Feb 19, 2006
Our Powerline devices have security that will prevent anyone from seeing your Powerline network. Using the utility provided with the device, you can encrypt all data transfers over powerline to 56 bit DES. In addition, the range of the powerline signal is limited, in order to help prevent others from accessing the data stream.
No, the ground wire does not interfere with any of the Powerline functions. The ground wire socket/third prong is a safety requirement for modern outlets and high-voltage equipment, and should not be tampered with.
We recommend that there be no more than 10 computers active on a Powerline network at one time. It is possible to have more than this, but throughput will be greatly diminished.
While *technically* the Powerline network can function when plugged into a low-end powerstrip, i.e. a powerstrip with a simple fuse, this *seriously* degrades performance, and can block the Powerline network completely.
No; the Powerline products have a built-in surge protector. Plug the unit directly into the wall socket.
tripp-lite 40kva ups rectifier on,but invertor not on ,alarm coming auxiliary supply abnormal
Efficient... | Answered on Apr 04, 2014
How far have you got and what exactly are you having trouble with - ?
Efficient... | Answered on Oct 30, 2010
Its asking for the username because in ur router, wi-fi protected set up(WPS) is enabled. Acsess the router's set up page using its default IP, and disable the WPS option, it wont ask for username and password anumore.
Efficient... | Answered on Aug 12, 2010
Any encryption key will be specific to a network so no there is not a free universal key. If you find a non encrypted network like at Panera Bread Co. then you don't need a key.
Efficient... | Answered on Nov 18, 2009
Dear Gatta,
for this conversion you have to install Adobe Professional 7 Version in your computer . by this software you can convert any Word and Excel file in to PDF and vice versa.
Takecare
Computers &... | Answered 36 minutes ago
Efficient Networks Siemens SpeedStream Powerline 2524 Wireless DSL/Cable Router (936-2524-001) Logo
6 questions posted
Top Efficient Networks Computers & Internet Experts
pongta rajkumar
pongta rajkumar
Jeffrey Groves
Jeffrey Groves
Duncan Mutch
Are you an Efficient Networks Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Efficient Networks Computers & Internet
Most Popular Question
neighbors or power company intercept
  • Computers & Internet
