20 Most Recent Sharp SJPT640RS Top Freezer Refrigerator Questions & Answers
Freezer not cooling
Freezer Fan is not working or Gas leaked from Compressor line.
3/3/2015 12:32:02 PM • Sharp SJPT640RS... • Answered on Mar 03, 2015
My sharp freez not cool
You can checked error with pressing select button for 5 second while Ref door open. If any defect in your ref error will display.
3/3/2015 12:08:27 PM • Sharp SJPT640RS... • Answered on Mar 03, 2015
How can I level the refrigirator doors
By adjusting doors you mean the reason door look uneven or doors wont close them self. Door can be adjusted by proper level of the fridge. Please remember the front legs or casters should be raised, so the door swings close. Also the door is attached to hinges which have some leverage.
5/27/2014 12:29:00 PM • Sharp SJPT640RS... • Answered on May 27, 2014
How do I change bulb in sharp fridge freezer
hello first unplug the fridge freezer from the power outlet. Look for the bulb compartment or socket where the light bulb is located then remove the bulb and then install a new one .Ensure replacement bulb is of the correct type and wattage then test the bulb
8/25/2023 7:18:50 AM • Sharp... • Answered on Aug 25, 2023
2answers
I have a Sharp Fridge-Freezer, model SJ-F78SP-BK. The Fridge compartment freezes. If left on overnight, everything will freeze as if it had been left in the freezer. Freezer is working fine.
Hi, please increase the temperature in the fridge portion of your fridge as it sounds like you've set that compartments temperature too low. Thank you.
11/15/2022 6:00:20 PM • Sharp... • Answered on Nov 15, 2022
What is wrong my smart sharp tv has all lines in it
The screen for your TV has quit working and your TV has stopped working.
11/7/2021 3:55:13 AM • Sharp... • Answered on Nov 07, 2021
Sharp model SJ-F78PE-SL fridge part not working
call your local repair service . sounds like the air damper control may have hic ups
7/10/2021 1:30:30 AM • Sharp... • Answered on Jul 10, 2021
How do I get the lamp cover off to replace the globe in my Sharp refrigerator? SJ-BB05DTXW1-EU
If your refrigerator has an incandescent bulb, you need to press in at the two hooks that secure the cover. See the picture here: https://www.manualslib.com/manual/1851908/Sharp-Sj-Bb05dtxw1-Eu.html?page=10#manual . Some models have LED lighting. For those models, the lamp is not user-replaceable. I hope this helps. Cindy Wells
6/14/2021 10:45:06 PM • Sharp... • Answered on Jun 14, 2021
2answers
How do I find the drainage pipe in sharp fridge freezer there is water running under veg compartment thank you
It is usually at the base on the back wall inside the fridge.
4/9/2021 4:36:53 AM • Sharp... • Answered on Apr 09, 2021
Sharp refrigerator SJ-F75PS-SL - Hinges Broke on one of the doors. Where can I find?
search appliance parts online for it
11/13/2020 7:42:55 AM • Sharp... • Answered on Nov 13, 2020
Sharp SJPT690R-S leaking water on floor BEHIND THE FLOOR DRAWERS in the refrigerator, not in the fridge.
Sounds like water line behind the fridge is leaking pull out fridge and inspect the small white tube.Note if you remove the line make sure to turn off water supply first to avoid water making big mess. Marcus
11/25/2018 3:13:47 PM • Sharp... • Answered on Nov 25, 2018
FANMOTOR NOT WORKING
Could be in defrost, or control could be bad.
10/27/2018 3:42:17 AM • Sharp... • Answered on Oct 27, 2018
tip
Refrigeration
Make; Sharp model: sj-f76ps i check and take another DC supply to run my m fan motor is good is working, but i notice there is no power is coming to activated my fan motor inside my refrigerator, i supposed that has to be r lead switch or sensor thermistor but i cannot identify whats wrong can you help me out please thanks from Harley.
on Oct 27, 2018 • Refrigerators
Hellow my sharp refrigirator fan is not working yet but fan is ok i checkd model Sj-434fg/fa/wg/wa i also change the bi- metl and fan fuse and also changed the timer Please advise ASAP
Door need to be close for fan to work or you can press the door switch .Check for power to fan
7/11/2018 8:09:30 PM • Sharp... • Answered on Jul 11, 2018
Sharp SJPT640RS Top Freezer Refrigerator Logo
3 questions posted
Top Sharp Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
Are you a Sharp Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Sharp Refrigerators
  • Sharp Refrigerators
Most Popular Question
level refrigirator doors
  • Refrigerators
