20 Most Recent
Leisure Components 1314 3Way Low Boy Hand Water Pump Questions & Answers
Our 131 faucet leaking from under the cover, is it defective?
if this is installed in a small rv , wow I know all about the problem with these , seems this type of pump allows one to draw water from a storage tank on board and the user provides the "power" via moving the handle up/down to draw up the water , but then when in the park you can connect fresh park water to faucet and using the same handle in opposite direction pressurized water flows out of it , first thing , its in a rv !! if inside air temp is not maintained 24/7 365 between 35F and 210F it plastic its gonna crack (mine did) and I don't know about you but my rv is outta my mind in the off season so no temp is being maintained inside it , if this is what happened then just replace it , no glue will hold up to its use ! second parks water pressures vary so carry your own water pressure regulator and use it between park and your rv ! these things only handle about 40 psi and then they crack open , and last but not least invest in some food grade rv antifreeze this is great stuff to "put up" the rv for the off season run it thru everything that gets water into it saves you tons on replacing things in the spring time
8/26/2015 2:54:15 AM •
Leisure...
Answered
on Aug 26, 2015
What are the advantages of using HDPE pond liner sheets for constructing a pond?
Here are the advantages of using HDPE pond liner sheets for constructing a pond:
- Durability and Puncture Resistance: HDPE is a tough material that can withstand wear and tear. It's resistant to punctures from rocks, roots, or other sharp objects that might be present in the soil under your pond. This translates to a long lifespan for your pond liner, minimizing the need for replacements.
- UV Resistance: Unlike some materials that degrade under sunlight, HDPE liners are UV resistant. This means they won't become brittle or break down over time when exposed to the sun, ensuring the liner lasts for many years.
- Chemical Compatibility: HDPE is non-toxic and resistant to many chemicals. This makes it safe for fish and plants in your pond, and it won't leach harmful chemicals into the water if you need to treat the pond with certain substances.
- Suitable for Large Ponds: HDPE liners come in large sheet sizes, making them ideal for constructing bigger ponds. The large sheet size reduces the need for seams, which can be weak points in a liner, and simplifies the installation process for larger ponds.
- Relatively Easy Installation: While professional installation is always recommended, HDPE liners are lighter than some other pond liner options and can be workable for DIY projects. They can be welded together to create a secure seam, and their flexibility allows them to conform to the contours of your pond.
- Cost-Effective in the Long Run: Although the upfront cost of HDPE liners might be higher than some other options, their durability and low maintenance requirements make them a cost-effective choice in the long run. You won't need to replace them as often, and they can help prevent leaks that could damage your landscaping or require repairs.
3/18/2024 7:08:38 PM •
Garden
Answered
on Mar 18, 2024
Where can I find a baumr-ag sx45 0.325 chainsaw cog
usually doing a bit of research on google con bring you up a parts list & suppliers. with the make and model number & then type in either service manual or parts list.pdf. of even a schematic can bring you pictures or websites to help. maybe some scrolling through is needed but you should be in the ball park with this one.
3/15/2024 11:12:06 AM •
Garden
Answered
on Mar 15, 2024
I would like to print out a service and parts manual for a 2015 ck30
Obtaining a service and parts manual for a specific model, such as the 2015 CK30, typically involves contacting the manufacturer or an authorized dealer. In this case, CK30 likely refers to a compact tractor model, and the manufacturer would be KIOTI.
3/9/2024 2:05:09 PM •
Garden
Answered
on Mar 09, 2024
Are the cushions on my outdoor sofa waterproof?
Cushion covers are treated with a water repellant coating. Spilledliquids can be easily wiped off. I would recommend removing andstoring the cushions in a dry place when not in use
3/6/2024 9:46:54 AM •
Garden
Answered
on Mar 06, 2024
