If you are saying your laptop shuts down when you remove the power cord then that's a sign that your battery is dead. Batteries only have a useful life, then after that they have to be replaced. Once the useful life is up, most times the battery will not take a charge. Some batteries will take a charge and say they are at 100% but as soon as you remove the power cord it doesn't take long before it is drained at 0%.
If your not able the boot from the HDD, enter BIOS by pressing F2 at startup. Then press F9 for default settings and then F10 for saving and reboot.. Maybe you need to provide more info.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.Capacitor Capacitors, sometimes also called condensers, are used to store energy in an electric field. In the context of computing, capacitors are used to block the direct current being circulated around the motherboard. A typical capacitor should last up to 15 years, but some computer manufacturers use substandard capacitors resulting in shorter lifetimes. Computer Problems b> When a capacitor has gone bad on a computer you may experience a large range of problems. The computer may have trouble booting up, or it may shut down without notice after running for only a short period of time. The most common problems associated with faulty capacitors are that they cause unexpected computer crashes and general reliability issues ranging from read/write issues to distorted screen images. b> Identifying a Bad Capacitor b> To identify a bad capacitor you will need to open your computer case and locate the capacitors on your motherboard. A bad capacitor may exhibit swelling at the top or the base of the capacitor or it may sit at an awkward angle with the motherboard, so compare the various capacitors in your computer in terms of and placement. Additionally, a bad capacitor may have a funny smell or it may have a brownish residue leaking from the top or the base. b> Prevention b> Manufacturers claim that capacitors may go bad because a computer is not receiving enough power from a power supply, because of an overclocked processor or because a computer is operating in an environment with too much heat or humidity. However, some capacitors prematurely fail due to faulty work on the part of the manufacturer. If you have a bad capacitor be sure to do research as to the lifespan of other products made by your manufacturer. Identifying bad capacitors http://www.youtube.com/watch?v=ngA4k32jLGc Capacitor replacement http://www.youtube.com/watch?v=s0Pn2tEjY04 How to check a capacitor http://www.youtube.com/watch?v=U4tnHA0phcc Replacing a leaking capacitor http://www.youtube.com/watch?v=s0Pn2tEjY04 The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable Test all power and data leads that attach to your hard drive SATA the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty. Although it would be very rare for the sata lead to be faulty. Make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty Computers need power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error Hope this helps.
I answered this question before however the switch may also be faulty that is possible or the keyboard may be faulty as well. I would have it checked out by a pro to see what the real problem is. Or if you want to bypass all that then just go and get a wireless USB stick and go that route as well. That is another option if you do not want to pay to have it fixed. You can get them cheap at amazon.com for around $15.00 or less. John
Malwarebyteshttps://www.malwarebytes.com
Malwarebytes gives you protection you can trust, alerting you instantly when we see your information has been stolen. Our live agents can even help you restore ...
Both have free versions, but I have bought both.
Then go to Startup and remove TSRs (terminate and stay resident programs) that have been added by new programs.
Look for a program called Sound Booster or one called DFX. DFX is my favorite because it not only boosts the volume, but lets you add other effects to enhance you sound as well. There is a free version. but to get all the effects you have to upgrade to the paid. If audio is important to you, check it out.
Try going into sound select and test reinstall driver off Asus website..if you installed new windows or update drivers may not work right...see if you can roll back driver in device manager ..if not lookup your laptop model and reinstall...
