20 Most Recent
Compaq Presario CQ62418NR 156 Notebook AMD Athlon II Dual Core 23GHz Processor 156 LED H (XZ276UAABA Questions & Answers
Will not power on
hi
does the laptop get power but not turn on?
it could be the power switch on the laptop or the ac adapter
it will need to be checked by a computer technician ask for a quote
cheers
Compaq c300 turns on then shuts down
Try removing the battery, reboot. Try another Power cord/charger with the EXACT same power specs. Clean the Fan and Vents with a Can of Compressed Air. Does it fully boot , then shut down?
Flickering screen
This is most likely a hardware problem (gpu or screen), did you reinstall the latest drivers for the gpu ? can you connect the laptop to a monitor with a vga cable to test further ? Otherwise it's best to go to the repair shop ?
I downgrade my os vista to xp..but no sound..i already installed the driver but doesnt work
Hello, welcome to Fixya!The sound is not working most likely because you did not download the right driver for the system.Go to the website of your computer, look for download/support or drivers on the homepage. You will be asked to enter your product model number, which is the model number of your computer, eg, Compaq A601..... Select your operating system and proceed for the driver download.Go to Audio driver, you might more than one drivers for audio. Download all the drivers and install them one after the other as one amongst the drivers should work with windows xp.I hope the above information is clear.Good luckWalesarumi.
My laptop is stuck on
Vicky, you haven't indicated whether you went into Safe Mode, as I recommended to you in your last statement,
http://www.fixya.com/support/t10782206-unplugged_let_rest_fewCan't get into Safe Mode?Different approach. Press the Power On button in, and hold it in for a count of 10 seconds. Computer should turn off. Yes, this is different than unplugging the computer from power.Now remove all power to the laptop. Remove the AC adapter (Charger), and Battery. Press the Power On button in, and hold it in for a count of 5 seconds. Let go of the Power On button. Do this same procedure 2 more times.(Watch the Power On LED light, as you perform this procedure. It may light up when you press, and hold the Power On button in the first time, maybe the second time. Should not light up on the third time )This is to clear CMOS Error Codes, and reset BIOS Setup back to the factory default settings.Post back in a Comment.Regards,joecoolvette
How do i turn on my LANconnection
Hey
Michael johnston,For what Wireless Button Used-Actually that button is used for Wireless Connections, WI-Fi or Wireless LAN.If you are connected with any wireless network,then it will disconnect you from such networks.
Indications-Blue- you are connected nowOrange- now you are disconnected ... you know well now..(LOL)How can connect with wireless network?Reach there and turned on wireless connection
Control Panel\Network and Internet\Network Connectionsif there is no success then try this one-or
Right click on network icon and then select Troubleshoot problem(Note- Don't forget to on that button. should be blue)Now troubleshooter will tell you what is issue.May be you have no wire less network in you area,or may be it will be turned off Do that if any issue connect me via comment on that answer.Good Luckor
Text size is too small
Hey
Robert Stone ,Nice to see you there.Buddy you dint mentioned your operating System i mean its vista, or windows 7.Let it go..Try this- Click on start Button
- Now write "Display" in search place.
- Then click on display link
- Now you can see the window ,with option to change size.
- Medium or Small as you wish Robert Stone
If still facing issue write here againDon't for get to rate me.. if you are satisfied only.
