20 Most Recent
Toshiba Satellite L750 Notebook Questions & Answers
What wrong with my computer?
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
9/25/2013 4:30:34 PM •
Toshiba...
Answered
on Sep 25, 2013
Help desk
You have too much storage ,you need to delete a whole lot of files,lap tops dont hold a lot of files,pictures and videos take up a lot of room,and then music will too,also run defrag and set it up to do so every day.See how much is trying to start up when booting up,if there is too many programs booting up with the os system it will cause this problem also.
5/12/2013 11:46:15 PM •
Toshiba...
Answered
on May 12, 2013
L750 block of colour on bottom half
Your lcd screen is going bad. It's either the lcd screen or the video
card inside the computer. To isolate the problem try connecting another
monitor to the computer. Borrow a monitor from a neighbor, friend,
relative or co-worker and connect it to the computer. If the Borrowed
monitor displays ok then your video card is ok, but your original
monitor is bad. If the Borrowed monitor displays the same as your
original monitor then your video card is bad.Plug in an external monitor and see if the
display shows up on it. It can be any kind of monitor even the old big fat crt
monitors as long as it has a vga cable to connect to your computer's vga
port. If the video shows on the external monitor that proves your video
card is ok, ,but your lcd screen is bad. The video will show on most systems
when you reboot without you having to do anything. Some systems will require
you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then
hit the correct key for displaying on the monitor (F1 thru F12). The
correct key will normally have CRT/LCD on it or it will have the icon of a
display.
6/8/2012 9:33:09 PM •
Toshiba...
Answered
on Jun 08, 2012
My toshiba laptop keeps turning off
This issue could be caused by any of the below possibilities.::::: Heat related issue. >> Hardware issue or error. >> Computer virus. >> Issue with operating system. >> Other failing hardware.... >>Two important things that you should do to fix a laptop which keeps shutting down are::::1- Scanning computer to eliminate malwares, spywares and the viruses from your laptop. 2- Repairing and cleaning Windows registry. Run a system utility tool like ReginOut to repair corrupt registry and windows files.
4/16/2012 10:16:10 AM •
Toshiba...
Answered
on Apr 16, 2012
How do i torn up volumn on toshiba L750
there are 2 easy ways first is by pressing the fn (function key) and number 4 at the same time or you can click the speaker icon in the bottom right corner of your screen and drag the slider up hope this helps
2/2/2012 3:10:54 PM •
Toshiba...
Answered
on Feb 02, 2012
Japanese Visa Application with COE denied. Why?
How to Get Employment Security With Correct Japan Work Visa Japan is no different from other developing nations whereby grass seems greener on its side of the pasture. It attracts its fair share of foreign businesses as well as nationals seeking to work within its lands. Albeit many adhere to immigration procedures, some choose to test their limits on the basis of ignorance or defiance. By understanding the different types of work visa in Japan, it assures its foreign workers a continual stream of income with no threat of arrest and deportation. Visa simply infers the status of residence. Citizens obviously have no need of it as they automatically satisfy qualifications to freely reside in their country of birth. As for those of alien status who wish to join the local workforce, there should be a category to match one's requirement. Since most countries strive to improve the overall quality of life, professionals are generally welcomed to contribute knowledge and skill. Unskilled labor is normally not granted a visa to avoid flooding and dilution of the workforce. The visa is awarded in accordance to one's area of expertise. Supported with proof of relevant experience, it is based on the field of involvement whilst working in the country. In the event one's work scope changes from one expertise to another, it is essential to apply for a visa under the new circumstances. Different types of work visa in Japan also apply to foreign companies seeking to conduct local business. Domestic companies based abroad wishing to set up a local point of presence need to provide supporting documents to justify internal transfer of foreign workers. Governmental staff for diplomatic duties is assigned a category for legal residence. Over and above the general groupings, designated activities also garner approval from the authorities. Domestic service for non-native residents and citizens of certain nations on working holidays fall into this category of working visa. This, by no means, is the end of the list as it is best to consult the authorities on which visa serves best.Click Here For More Details: http://japanjobandvisaservice.com/blog/change-your-luck-when-apply-work-visa
5/22/2023 2:52:35 PM •
Toshiba...
Answered
on May 22, 2023
