Ok. This is easy. Two views are offered for you. The first look provided . It's a good resource and a similar discussion is going on,
samsung RS267TDBP Refrigerator Defrost Issue Service manual request The... . If you get stuck and need immediate action. There is a tech with a first free offer that should prove value beyond this one. If you need it.
Take notice to the picture seen in the discussion and the location of the plug to the cooling coil. The plug for the sensor is removed. Since the sensor resembles a pickle , another link is offered to identify that one,
Dappz com Quality Parts . The female side of the plug adapter is seen on the back wall inside the refrigerator; with the cover removed. The reason for this approach is gaining confidence researching.
Here is the hands on approach.
This is a different source .
Here is the link straight to the technicians manual for the entire system at your fingertips.
http://appliance911seabreeze.com/RF267AER_Service_Manual.pdf .
The pdf file locations for your interests is located:
The evaporator in the refrigerator is page 36, (3-18).
The evaporator in the freezer is page 41, (3-24).
Downloaded from
www.Manualslib.com manuals search engine.
This is absolutely a CANDO project. Just remember. Safety first. Better to power down than to get yourself powered up. Machines are sensitive too. I have spent almost as much time for you researching your learning experience as it will take to perform the repair. Please value your experience. Be sure. Then pay it forward. You can do it.
