it could be the latch frame and casing but if no one has recently put a crowbar in to door lock to force your door open - i would say its an eletrical fault check the sensor on the door frame and on the door and make sure they line up while the door is closed and if thats the case i would say you have a fault with the hall sensor or ghosts haha just kidding
Quorahttps://www.quora.com > What-does-CL-mean-on-a-dish...
This code means that the CHILD LOCK or CONTROL LOCK feature has been activated. When activated, all buttons will not change except the washer's door and the ...
9 answers · Top answer: First, look on your dishwasher to find a label that shows the manufacturer and the model number. ...
JustAnswerhttps://www.justanswer.com > Appliance Repair
Oct 28, 2010 - You should just be able to just turn the power button off, then turn it back on and the CL should be gone.
1 answer · Top answer: Hello, and thank you for using this service. I'll be helping you with your
..https://www.youtube.com/watch?v=Xr4DBwACUW4
Dishwashers come in standard sizes. Your old one is 60 CM wide and made for built in.
https://www.bosch-home.ca/en/supportdetail/product/SGU4025AU/31
DISHWASHER 60 CM BUILT-IN/BUILT-UNDERSGU4025AU/31
As long as the new one is also for built in, the dishwasher will fit. Measure the height of the space you have. There may be a little height adjustment on the feet.
AI Bot Answer Deleted.
In the base of the dishwasher above the floor there is a plastic tray that has a leak sensor. If you see water behind the machine than it means you have a 'spraying leak' as the sensor cuts off the machine as soon as it is triggered. It is likely to be a leaking hose on the pump. It can also be caused by the machine over-filling.
An E15 error code indicates that the safety switch has detected water in the base of the dishwasher. Your leakage protection system has activated. What can I do to fix the E15 Error Code on my dishwasher? Please turn off the water inflow and contact Bosch Customer Support for assistance.
Check if there is anything in the large item trap or blocking the water level sensor. The dishwasher won't try to fill if it believes it is full. Try pressing and holding the Start button for 3+ seconds. The Clean LED should light up in a minute. If it does, try the on/off button and starting a new cycle. (This just clears any old programs from the memory.) Some washers will stop if they detected a water leak. Sometimes turning off the power for a while and checking for water in the cabinet below the dishwasher or in the motor area is useful.
The more likely items to check: Check the wiring between the inlet valve and the control board. Check the wires for corrosion at the connecting pins and for continuity. Broken conductors don't send a signal to open and close the valve. If those are okay, then the control board itself may be faulty.
Since this dishwasher is discontinued by the manufacturer, I don't know if all of the parts are still available. The only parts list for the SHE3ARL2UC/28 that I found is here: https://www.partselect.com/Models/SHE3ARL2UC/ . They don't list any wires or the control board.
I hope this helps.
