20 Most Recent
1961 Rolls Royce Silver Questions & Answers
How do i test the fuel pump on 1961 silver cloud II
There is blockage/restriction in the fuel line between the fuel pump and the carburetor. I suspect there may be a fuel filter in the line somewhere, so check for that. You can disconnect the line from the fuel pump and from the carburetor, and see if you can blow compressed air through the line. Check in both directions - if there is something stuck in there, it may be dislodged by the air pressure and come through.
Electronic ignition conversion for early Rolls Royce Silver Spirit
Kits. Choose the one that best fits your situation.
PERTRONIX ELECTRONIC IGNITION KIT (ELEC5) ' Flying Spares
Pertronix Electronic Ignition Kit (ELEC5):
Part Number: ELEC5
Suitable for: Cars with Opus ignition (1974 to 1983) - Silver Shadow / Bentley T from VIN 22118 and SZ models up to 1983 (VIN 06969)
Description: This aftermarket kit replaces the Opus ignition system with a Pertronix electronic ignition. It's a self-contained unit that eliminates the need for points and condenser. Installation is straightforward with only two wires to connect, and no permanent modifications are necessary. The hall effect sensor ensures durability and accuracy, even in harsh conditions. Benefits include increased spark plug life, improved fuel economy, and smoother engine running.
Coil Replacement: When fitting this kit, you'll need to replace the coil with a 1.5 Ohms coil (such as COIL1 or COIL2).
Compatibility: Suitable for late Silver Shadows, Bentley T, and early Silver Spirits up to chassis CH06969.
Price: US$303.57 .
Pertronix Electronic Ignition Conversion Kit (ELEC3):
Suitable for: S3 and Silver Cloud III, as well as Silver Shadow & Bentley T1 before VIN 8742.
Description: Converts your distributor from points to electronic ignition .
Pertronix Electronic Ignition Conversion Kit (ELEC4):
Part Number: ELEC4
Suitable for: Single Point Ignition cars from VIN 8742 to 22117
Description: Another option for converting your distributor from points to electronic ignition
Where is the started relay on a 1979 Rolls Royce Corniche located
Rolls Royce, especially the older classic models, are known for having relays and solenoids mounted in strange places in the engine bay. You could find the starter motor and tracing the small wires back until you find the relay. I would also suggest you try some of the Rolls Royce owners forums as they will have a more specific knowledge of the wiring layout.
1984 silver spur kick into passing gear blowes #27 fuse for starter,replaced kick down switch still blowes fuse?
You can get guide from many sites.. i know few
like reliable-store
error codes/ fault codes, wiring diagrams, schematic diagrams, torque specs, engine info, switches functioning, assemble, disassembly, complete refurbish, repair, installation every single thing is covered
within seconds u can get the access and it's totally illustrative complete
