20 Most Recent
1989 Lotus Esprit Turbo Questions & Answers
1989 Lotus Esprit turbo, starts won't idle, shuts off after 2 seconds.
I do not know your vehicle but in that time frame a lot of cars used what is called a ballast resistor. During start it was shorted allowing the coil to output more power, once the engine came up to speed about two seconds the short was removed. Shorting simply means bypassing the resistor. I hope that helps.
I have a 1986 Lotus Turbo Esprit. Power cuts off
have to be quick ,got to get er indoors from work,or an earbashing .right back to car talk --not exactly sure what iam dealing with here ,carb or injection ,it has a distributor if its an 86 but does it have points or a module inside the distributor or just a pick up with the module under the coil ,Also this turbo ?? someone put new bearings in?? or the rotors as well .must dash i have 5 mins to go and get the old dragon
Looking for a lotus expert mechanic in nj
HI, sorry I am not closer, but the mechanics are very easy for any good mechanic, if you get a workshop manual from a UK Lotus specialist (sjsportscars). they do all parts mailorder the manual is very detailed, if you have a standard model, if you have the US high spec most race shops can tune the engine
Where is the trunk release on the Lotus Evora S?
it is in and or under the back seat. put it toward the middle of the car. if not you will brake it and the truck will not close. So you might want to go to the dealer to find out if there is a fix now to get the cable replaced so if you try to open it the wrong way at least you can close the trunk
