20 Most Recent Sony Ericsson Xperia Play Questions & Answers
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Sony Ericsson... | Answered on Feb 01, 2018
you phone all function is work but your screen are gone you have to change your LED screen
Sony Ericsson... | Answered on Jul 10, 2017
re install the phones software with a pc on the internet
Sony Ericsson... | Answered on Oct 13, 2013
i want unlock code for sony ericson play R800a IMEI 357303040199249 unlock code sen to my email deviljayson18@yahoo.com tnx
Sony Ericsson... | Answered on Jul 10, 2013
I would check all your setting options. Check for applications that are running in the background, check WiFi On/Off, check GPS On/Off, check 4G (LTE) On/Off, and check for Auto-Updates On/Off. I would also removed Live Wallpapers and unnecessary Widgets that are roaming around the Home Screen. Try to terminate background apps and apps that you aren't using. If you have an app that you launch and ads pop up, sometimes that app will give your phone data roaming if it is not terminated.
If these options do not solve your problem, I would take it to your nearest cell phone provider and check the issue. Some instances they will replace your battery for free.
Sony Ericsson... | Answered on Jun 30, 2013
ma f'in fone got ribbon problem x'play screen stays blank but everything working fine but I cant see whats going on !! I have tried to repair that **** for ma self but I couldnt open bluuudy one screw drive bcoz it was freaking damaged and it look like f'in old screw f'in chinese mn did not have freakin enough screws !! any idea for da bluddy old chinese screw out ? if dont no worry da phone will be sent to da f'in made in china were born in Japan **** ma LAN im done bluddy chinese run b4 I get da gun keep on run shoot ya to japaan.....
Sony Ericsson... | Answered on Aug 13, 2012
Your cell phone may be locked to a particular cell phoneprovider and in this case it needs to be unlocked to use with a different cellphone service provider.To get the security code/restriction code to unlock the cellphone from the current cell phone provider so you can use the SIM card with adifferent phone provider, Please click on this link and follow my instructions:-http://www.fixya.com/support/r4049238-unlock_cell_phoneIf yourphone provider does not help you then these WEB sites it provides securitycodes for a small price.http://www.mobileunlockstore.com/?gclid=CKDb2_y2558CFSlJagodxBkDHwhttp://www.mobileunlocksolutions.com/
Sony Ericsson... | Answered on Mar 24, 2012
Unlock code at a free of cost is not possible for your sony ericsson mobile but you do not worry about this one surely you can get a code at a reasonable cost itself...........
Get the unlock code for your sony ericsson xperia model mobile from this site Wickedunlock.com , it gives the easy methods to get the mobile unlocked........
Sony Ericsson... | Answered on Feb 07, 2012
Hello
It is very likely the screen has burned out, it can be replaced, just contact any local cell phone shop that is "full service" for a repair estimate. It will be fairly expensive to repair so if you have considered upgrading to a newer phone I'd say now would be a good time. You can also buy parts on-line for this, you will need a special tool kit to take it apart however, you can find the parts and the tool kit on eBay for most popular models.
Could you please rate my solution for Fixya, it is all i ask for my time and effort to help you. Thanks
Sony Ericsson... | Answered on Dec 29, 2011
Sounds like you need a PUK code? Thus is available from your network carrier. Resetting the phone isn't going to fix your issue!
It is locked by the phones IMEI No (every handset has its own IMEI, even an apple watch for example.
Sony Ericsson... | Answered on Mar 30, 2019
Use the below method with caution because it wipe all of your data
1. Turn Off Your Device. if the device is freezing Remove Battery and insert few second.
2. Press and hold Left key + Right Key Together Press Power Buttonuntil vibrates.
3. Now select "factory reset (full wipe)"
4. then select "Yes"
wait for few seconds
5. after finish Hard Reset Select Reboot System Now
Your Device will be auto restart
Done.
Sony Ericsson... | Answered on Mar 13, 2019
You can get the Unlock code from here Simpleunlocking.com
and follow the instructions below and unlock it step by step:
Sony Ericsson Xperia X8 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Sony Ericsson Xperia X8 mobile phones. If you enter over a certain amount of wrong unlock codes on your Sony Ericsson Xperia X8 mobile phone, your phone may get hard locked and sometimes become unusable.
1. Switch ON your Sony Ericsson Xperia X8 with a Not Allowed SIM Card.
2. Your Sony Ericsson Xperia X8 will request to enter an unlock code.
3. Tap the box where you have to input the code and a number pad will appear.
4. Type in the unlock code we send to you.
5. Press the 'Unlock' button on the phone.
6. Your Sony Ericsson Xperia X8 phone should now be unlocked.
Sony Ericsson... | Answered on Feb 04, 2019
IF THAT LANGUAGE IS NOT LISTED IN THE SETUP MENU THEN YOU WILL NEVER GET IT
Sony Ericsson... | Answered on Nov 21, 2018
Apparently 10 year old phones can still be purchased on eBay.com and other web sites. Perhaps purchase an identical model to see if parts can be used or what can be swapped.
Perhaps a local repair shop could help you.
https://www.ebay.com/bhp/sony-ericsson-k800i
Sony Ericsson... | Answered on Oct 24, 2018
Sony Ericsson Xperia Play Logo
Popular Tags
44 questions posted
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Marvin
Marvin
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Ericsson Cell Phones
Most Popular Question
reset hardlocked xperia play
  • Cell Phones
