20 Most Recent
LG Thrill 4G Questions & Answers
Unlockinging LG Thrill
Free unlock code is not possible you can get only paid unlockservices. You can get unlock services at reasonable cost from the online site
Onlinegsmunlock.com. You can unlock your LG Thrill 4G using the unlock codes.
12/2/2014 8:00:36 AM •
LG Thrill 4G
Answered
on Dec 02, 2014
Bricked lg thrill
CWM Recovery only supports FAT32 partitions on External SD card's if your SD Card is larger than 32Gb than most likely it is formated as exFAT which is not supported by CWM Recovery either reformat your card to FAT32(be sure to move your backup temporarily to your PC because formating it will erase all data from the SD card. Another alternative is to use TWRP(TeamWindowsRecoveryPro) instead but i'm not sure if TWRP is available for the LG Thrill or not(Google TWRP for LG Thrill and see if it's available)
7/3/2014 2:44:03 AM •
LG Thrill 4G
Answered
on Jul 03, 2014
Lg thrill wont charge
Date: May 16, 2014
I have an LG Thrill 4G. My phone just went thru an issue where it wouldn't charge past 4%. Sometimes, it wouldn't go past 2%, so I had to leave it on the charger ALL the time - or risk it dying, completely.
For days, the only services shown on my battery usage were:
Cell Standby: 33%
Bluetooth: 33%
Phone Idle: 32%
Display: 2%
I replaced the battery with a brand new one - NOTHING changed. Battery still sat around 2-4% for the entire day, while on the charger. So, I started uninstalling apps like crazy - just to see what would happen.
NOTHING. Same thing.
So, I decided to at least install the Facebook app back...and the upgraded version had to be installed - so I did it.
VOILA!!! My phone instantly started charging ...8%...14%...24%...52%...80%...91%...all over a period of about an hour. Just a constant charge going up a few percentage points every few minutes...
...and all of a sudden, started going back down pretty rapidly when it hit 92%. Within maybe 3mins, the charge went from 92% to 78% - and I wasn't using the phone. I was just watching the meter drop 2 percentage points over a period of a few seconds, each time. I decided to quickly turn the phone off at 78% but left it on the charger.
After roughly 5mins, I turned the phone back on, just to see what the charge would be sitting at. WOULDN'T YA KNOW - 3%.
How can battery life go from 78% to 3% - while it's OFF - within a 5min span??? Therefore, my question is: was it really charged to 78% when I turned the phone off? Or was the battery meter being "tricked" by some app that might be installed?
The first battery it did this to was the 1500mah. Used that battery for like 3 days of this before I replaced it. The battery the scenario above JUST happened to is my new 3500mah battery, and it's been giving this 3500mah battery the 3% capacity for a whole day and a half now...
5/17/2014 4:43:04 AM •
LG Thrill 4G
Answered
on May 17, 2014
I have a LG Thrill pay as you go and the internet doesn't work without WiFi, help me please!!
Hi. I just got an LG Motion and found this problem too. Go to the "other Apps" logo which is grey (on my phone) and shows 16 dots in a square. Scroll over to Google Chrome. This will be your browser. Add an icon for it to your main screens. It should open right away. In Settings, the WiFi slide button should be BLUE. That means it is on. Make sure you are fully charged and the glitch Power Saver doesn't come on (I think it shuts down Wifi).DONT click "Easy WiFi" bc that just looks for a preexisting WiFi connection!!Google Chrome!!!!Good Luck.
2/8/2013 11:17:35 PM •
LG Thrill 4G
Answered
on Feb 08, 2013
Lg thrill will not turn on
1.Check the device's battery level for at least two bars of strength. 2.If the battery level is low, charge the battery. 3.If the issue is not resolved, remove the back cover. 4.Remove the battery. 5.Wait 10 seconds. 6.Press and hold the W key. 7.While pressing down the W key, re-insert the battery. •The device restarts and after approximately 15 seconds, the 'Recovery' screen appears•Release the power button but *continue holding the home button*, for another 30 seconds.StepThanks
1/6/2013 4:07:42 PM •
LG Thrill 4G
Answered
on Jan 06, 2013
Apps won't download
It's probably because you phone isn't the new version so you should update your phone
1/3/2013 7:35:22 AM •
LG Thrill 4G
Answered
on Jan 03, 2013
It started out that i couldnt recieve pi
for sending text messages :1.go to your message settings and check the message center number to see if it is correct2. call to your network operator customer care3. request the message center number...4.note it down5. go to message settings>message center number6. insert the number which is noted by you and save itthis solves your messaging problem ...Good luck
11/7/2012 4:32:45 PM •
LG Thrill 4G
Answered
on Nov 07, 2012
