20 Most Recent
Samsung Galaxy S II Questions & Answers
Forgot my voicemail password how can I find it or change it
Try
step-by-step procedures.
1. Press and hold 1 or Voicemail key to call into the voicemail system from your wireless device.
2. Press the * key to skip to the Main Menu, otherwise go to Step 3,if you have new messages.
3. Press 4 for Personal Options.
4. Press 2 for Administrative Options.
5. Press 1 to Change Password.
6. Follow the prompts to enter a 4- to 15-digit password
7. Press the # key.
How to install apn on Samsung galaxy S2
Once in the APN setting page, tap 'Menu > New APN' and fill up the required fields.In case you happen to not know anything about those details, please, tell me your country and carrier. I would do my best to fetch those settings for you.Anyway, please, let me know if you need further informations.Regards,Carlos
S2 unlocker
Do you want to remove the country lock?You can approach
Classicunlocking.com and get the required country unlock code for your Samsung Galaxy S2.You need to specify the country,locked network and based on the availability get the unlock code along with free instructions.
How to unlock G S II
You can unlock your Samsung Galaxy S2 from Network lock easily by using unlock code.To get this code at low cost visit the site
Unlock-zone.com here you need to specify the IMEI number of your phone,Country,Network provider to which it is locked.Then they deliver the unlock code to you through E-mail.Using that code you can unlock your phone easily.After unlocking from Network lock,you can use any GSM network SIM card on your mobile.
Samsung galaxy s2 dead and i cant even turn on my phone
If you've got your phone brick try to put it into "restore" mode: <vol-down>+<home>+<power> and keep them pressed until you see restore screen. If that didn't work try to <vol-up>+<home>+<power> - you'll go to "download" mode. If that works then you're lucky and you'll be able to restore your phone. Give me a private shout @
[email protected] I'll provide you detailed instructions.
