20 Most Recent Sony Ericsson Xperia Arc Questions & Answers
pin =PERSONAL IDENTIFICATION NUMBER which fixya does not have or access to your accounts if bought this new you can try your provider for assistance with proof of ownership --if bought used can try provider
Sony Ericsson... | Answered on Jun 06, 2017
Leave it charging for an hour without trying to turn it on. After an hour with its proper charger, turn it on.
Also, try holding volume up and power at the same time for 3 seconds.
Another way to perform the above is to look in the side SIM card slot for a red button. Push it gently for a second.
Sony Ericsson... | Answered on Jun 30, 2016
Needs to be recovered probably. Don't know if it will help but you could try holding power and down volume. May get into recovery mode and let it recovery itself, otherwise it's reflash time.
Sony Ericsson... | Answered on Dec 04, 2015
Press the function button(FN), the start button ( I mean the Windows symbol) and the Prt Sc button together .
Sony Ericsson... | Answered on Sep 22, 2015
check with the manufacturer, quite likely it is not possible to connect with laptop .
Sony Ericsson... | Answered on Sep 01, 2015
Press the home button and the down volume button together For 5 seconds
Flash new software from Apple or other mfg. That's pretty much it. Sounds stolen.
Sony Ericsson... | Answered on Aug 28, 2015
If you haven't already, restart your device and try your download again. If you're still having trouble afterwards, try these
check your data connection
make sure download manager is turned on
clear cache and data
reinstall playstore updates
check for system updates
Sony Ericsson... | Answered on Jun 25, 2015
the charging pin of ur phone is not working properly ..... take it to the service statio they will fix the problem
Sony Ericsson... | Answered on Nov 06, 2013
I'm an avid fisherman and befor I wised up to leaving my phone or putting it in a plastic bag, I had dropped many in the water. I would then take the covers off the phone and set it on the dashboard of my car for a few hours - sometimes up to 3 days - flipping it occasionally to let water evaporate out of all holes. This always worked for me
Sony Ericsson... | Answered on Mar 30, 2013
The IMEI number is unique the each mobile/cell phone. The number is printed on the label under the battery. You can also get the IMEI number by entering this on your phone *#06# It will then display your IMEI number and you may also get a unique global serial number. Your IMEI number should be 15 digits.
Sony Ericsson... | Answered on Jan 24, 2013
for sending text messages :
1.go to your message settings and check the message center number to see if it is correct
2. call to your network operator customer care
3. request the message center number...
4.note it down
5. go to message settings>message center number
6. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
Sony Ericsson... | Answered on Jan 13, 2013
are you using the charger that came with the phone? I ask because I've run into in the past that if you try and use a different charger it may not work on your phone. you should use the one that came with the phone. having said that, you might want to try a different usb charger if that doesn't work it's probably the battery. Li-Ion batteries have charging circuits built in that can fail and also prevent the battery from charging if it's gone bad.
Sony Ericsson... | Answered on Nov 09, 2012
Please sms.
Sony Ericsson... | Answered on Oct 05, 2012
You need to Unlock your sony ericsson phone from network lock to use with other GSM Network Sim card...Without Unlocking you can't use with other GSM Network Sim card.Get the unlock code from the site
Onlinegsmunlock.com/unlock-your-phone/rs7wp2/ and unlock it easily...............
Sony Ericsson... | Answered on Jul 28, 2012
Sony Ericsson Xperia Arc Logo
43 questions posted
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Marvin
Marvin
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Ericsson Cell Phones
Most Popular Question
factory format phone isnt turning
  • Cell Phones
