20 Most Recent
Indesit IWC6125 Front Load Washing Machine Questions & Answers
Why does belt keep coming off when spinning?
Sadly, this is almost certainly drum bearings worn out and the drum spins off centre, causing the belt to come adrift (I'm guessing your spin cycle has become significantly noisier recently). Worse news I'm afraid, the IWC6125 uses a sealed, non serviceable drum, so this is really an uneconomical repair that will cost around 60%-75% of the cost of the machine when new
Front panel seal
Theres probably a clip of some kind that holds it from the inside frame
Door won't lock
try pushing the door and hold in if this does not work the door catch is faulty replace internal door lock then should work (common fault)
Indesit index XWA91683 will not start Wash Mode?
If your Indesit XWA91683 washing machine fills with water but does not start the wash cycle, and you have confirmed that the pump is working fine, there could be a few potential causes for the issue, including a malfunctioning motherboard. Here are a few steps you can take to troubleshoot the problem:
- Power Cycle: Start by turning off the washing machine and unplugging it from the power source. Wait for a few minutes, then plug it back in and turn it on again. This can help reset the machine's internal settings and may resolve temporary issues.
- Check Door Interlock: Ensure that the washing machine's door is securely closed and the door interlock mechanism is functioning properly. A faulty door interlock can prevent the machine from starting the wash cycle. Check for any loose connections, damage, or obstructions in the door interlock mechanism.
- Reset the Control Panel: Depending on the model, your washing machine may have a combination of buttons or a specific sequence to reset the control panel. Consult the user manual for your Indesit XWA91683 or contact Indesit customer support for instructions on how to reset the control panel to factory settings.
- Examine the Control Board: If the above steps do not resolve the issue, there could be a problem with the motherboard or control board of the washing machine. Inspect the control board for any visible signs of damage, such as burnt components, loose connections, or corrosion. If you notice any significant issues, it may be necessary to replace the control board. Consult a professional technician or contact Indesit customer support for further assistance.
It's worth noting that diagnosing and repairing issues with the motherboard or control board typically require professional expertise. If you are not confident in handling these repairs yourself, it is recommended to consult a qualified technician or contact Indesit customer support for assistance. They will have the knowledge and tools to accurately diagnose the problem and provide appropriate solutions.
